Vista - invalid connection file on remote desktop connection
Old 12-19-2008   #1 (permalink)
Kaheer
I am trying to establish a remote desktop connect with another computer. I
have windows vista home premium 64 bit edition. However whenever i do this i
get an invalid connection file error. I do not have any problems connection
from other computer which is a vista home premium computer.
Old 12-19-2008   #2 (permalink)
Mark L. Ferguson
Re: invalid connection file on remote desktop connection
The best way to repair invalid system files is with SFC
Click Start, and then type cmd in the Start Search box.
In the results area, right-click cmd.exe, and then click Run as
administrator. You will be prompted to type the password for an
administrator account. Click Continue if you are the administrator or type
the administrator password. Then, click Continue.
At the command prompt, type Sfc /scannow, and then press ENTER.
The scan may take some time. Windows will repair any corrupted or missing
files that it finds. If information from the installation CD is needed to
repair the problem, you may be prompted to insert your Windows Vista CD.
Use the "Ratings" feature. It helps the new users.
Need more Answers? Try the new Microsoft Answers pages.
http://answers.microsoft.com/en-us/w.../dd228912.aspx
Mark L. Ferguson MS-MVP
https://mvp.support.microsoft.com/profile/Mark.Ferguson
"Kaheer" <Kaheer@xxxxxx> wrote in message
news:84B72302-6727-4C1B-9F42-0E0452224917@xxxxxx
> i
> connection
Remote Desktop Connection Vista General
Fixed! Remote Desktop Connection (RDC) SLOW/NO Connection Issue Vista networking & sharing
Can't login to remote comp. using Remote Desktop Connection on Vis Vista account administration
remote desktop connection? AKA remote access? Vista General
Remote Desktop Connection Vista networking & sharing
