| Vista Home Premium | Does system restore restore previous security settings? i messed up the security permission for c: it supposed to be owned by trustedinstaller... can anyone post a screenshot for c: ---> properties ---->security tab.. need to see wat have i gone wrong and how can i fix it?? how can i restoreto the default permisson settings???? Last edited by projectnew; 12-20-2008 at 10:35 AM.. |
| | Re: Does system restore restore previous security settings? "projectnew" <guest@xxxxxx-email.com> wrote in message news:1ac6e1d24a543b1659ed121e510749d8@xxxxxx-gateway.com... Quote: > > for example the owner of c: > > > -- > projectnew It is better if you fully describe your problem, or concern, using the body of the message rather than the subject line. What is your concern? No one owns the C: drive. You post is not clear. |
| Vista Bussiness x64 PL | Re: Does system restore restore previous security settings? |
| Vista Home Premium | Re: Does system restore restore previous security settings? then how can i restore to the default permission? |
| Vista Bussiness x64 PL | Re: Does system restore restore previous security settings? Quote: Originally Posted by projectnew then how can i restore to the default permission? The Application Failed to Initialize properly (0xc0000022) Click Ok to Terminate the I've tried restore permissions by using command icacls -although my scripts theoretically are fully correct practically fail on C:\Windows. When script meet some file which is busy -system refuse changing permissions for this file -returns error "access denied" although you are already the owner of this file - interesting:in this situation there is no problem to change permissions for this file by using classic method:Take Ownership of file Folder Permissions ![]() But what important:if this kind of script meet error and can't change permissions for any file -all operation are stopped and don't work later although sometimes can return "success" but really there is no any success.Untill now I thinking (without any destination) how to fully restore permissions but untill now I don't know resolve. If you have any trouble with permissions you should describe your problem - there is also tool Process Monitor which use to detect trouble with permissions |
| Restore Previous Versions - Restore or Remove from Context Menu | Tutorials | |||
| System Restore messed up settings!!! Please Help | General Discussion | |||
| System Restore settings | Vista installation & setup | |||
| System Restore: do restore points persist after a restore? | Vista General | |||
| Settings Gone; System Restore Tried But No Good | Vista performance & maintenance | |||
