| 12-20-2008 | #1 (permalink) |
| | screensaver does not let the monitor turn off ? I have Vista Ultimate, I noticed that the "turn off monitor" power option does not work if I set a screensaver. Why is that? How can I have both working? thanks for your help Lucia Italy |
| My System Specs |
| 12-20-2008 | #2 (permalink) |
| | Re: screensaver does not let the monitor turn off ? Have you checked control panel / power options? Carlos España "Lucia Grassi" <LuciaGrassi@xxxxxx> escribió en el mensaje de noticias news:CFEBF8D9-CCCB-4269-9A59-EF7B05272F9A@xxxxxx Quote: >I have Vista Ultimate, I noticed that the "turn off monitor" power option > does not work if I set a screensaver. Why is that? How can I have both > working? > > thanks for your help > > Lucia > Italy |
| My System Specs |
| 12-20-2008 | #3 (permalink) |
| | Re: screensaver does not let the monitor turn off ? yes, that is what I did "Carlos Rivero" wrote: Quote: > Have you checked control panel / power options? > > Carlos > España > > "Lucia Grassi" <LuciaGrassi@xxxxxx> escribió en el > mensaje de noticias > news:CFEBF8D9-CCCB-4269-9A59-EF7B05272F9A@xxxxxx Quote: > >I have Vista Ultimate, I noticed that the "turn off monitor" power option > > does not work if I set a screensaver. Why is that? How can I have both > > working? > > > > thanks for your help > > > > Lucia > > Italy > |
| My System Specs |
| 12-20-2008 | #4 (permalink) |
| | Re: screensaver does not let the monitor turn off ? Hi, Are you using photo's as a screen saver? If so there seems to be a problem with powering down the monitor with that screen saver. I have read that since the photos screen saver can play videos and videos, by default, load an audio component (even though no audio is used in the screensaver) it is this audio component that keeps the monitor on. -- Paul "Lucia Grassi" wrote: Quote: > yes, that is what I did > > "Carlos Rivero" wrote: > Quote: > > Have you checked control panel / power options? > > > > Carlos > > España > > > > "Lucia Grassi" <LuciaGrassi@xxxxxx> escribió en el > > mensaje de noticias > > news:CFEBF8D9-CCCB-4269-9A59-EF7B05272F9A@xxxxxx Quote: > > >I have Vista Ultimate, I noticed that the "turn off monitor" power option > > > does not work if I set a screensaver. Why is that? How can I have both > > > working? > > > > > > thanks for your help > > > > > > Lucia > > > Italy > > |
| My System Specs |
| 12-21-2008 | #5 (permalink) |
| | Re: screensaver does not let the monitor turn off ? no, I am using the standard windows screensaver "PaulB" wrote: Quote: > Hi, > Are you using photo's as a screen saver? If so there seems to be a problem > with powering down the monitor with that screen saver. I have read that since > the photos screen saver can play videos and videos, by default, load an audio > component (even though no audio is used in the screensaver) it is this audio > component that keeps the monitor on. > -- > Paul > > > "Lucia Grassi" wrote: > Quote: > > yes, that is what I did > > > > "Carlos Rivero" wrote: > > Quote: > > > Have you checked control panel / power options? > > > > > > Carlos > > > España > > > > > > "Lucia Grassi" <LuciaGrassi@xxxxxx> escribió en el > > > mensaje de noticias > > > news:CFEBF8D9-CCCB-4269-9A59-EF7B05272F9A@xxxxxx > > > >I have Vista Ultimate, I noticed that the "turn off monitor" power option > > > > does not work if I set a screensaver. Why is that? How can I have both > > > > working? > > > > > > > > thanks for your help > > > > > > > > Lucia > > > > Italy > > > > > > |
| My System Specs |
| 12-21-2008 | #6 (permalink) |
| | Re: screensaver does not let the monitor turn off ? I have seen more in detail what happens: if the scrensaver is on, the monitor turns off but after less than a second it turns on again |
| My System Specs |
| 01-28-2009 | #7 (permalink) |
| | Re: screensaver does not let the monitor turn off ? Is anyone there able to help me? Still trying to find a solution "Lucia Grassi" wrote: Quote: > I have seen more in detail what happens: if the scrensaver is on, the monitor > turns off but after less than a second it turns on again |
| My System Specs |
| Similar topics to: screensaver does not let the monitor turn off ? | ||||
| Screensaver on external monitor not working | Vista General | |||
| Photos Screensaver ignoring power settings that Turn off the displ | Vista General | |||
| Screensaver and dual monitor | Vista General | |||
| since patch tuesday i can't turn off screensaver in vista | Vista General | |||
| Screensaver and monitor sleep don't work | Vista General | |||
