Vista - System Restore Taking Forever?
Old 12-22-2008   #1 (permalink)
Vista Home Premium 32bit
Hi. I decided to do a system restore, to a previous point that I made awhile ago.
The problem is, I believe it might be frozen. I did the system restore, but when it went to the blue screen where it says that the "System Restore is Initializing", it was stuck there for about 2 hours. Then, it switched to "System Restore is Restoring the Registry", and it's been stuck there for about 3 hours.
I've been tempted to use the power button, though it said that I shouldn't.
So, what should I do? :/ [It's been restoring for about 5 hours now, total.]
So I guess I'll post a bit of info about my laptop..
Running Vista Home Premium 32bit
Used up 150gb out of 250gb
1.66ghz duo cpu
And..Yeah. Will shutting it down harm my laptop?
Old 12-22-2008   #2 (permalink)
dev
Re: System Restore Taking Forever?
/MasterPenguin/ said:
> awhile ago.
> shouldn't.
> total.]
> 1.66ghz duo cpu
For the future you might consider an imaging utility that will restore
your every file, setting, and programs in a short time. Two good ones
are profiled at these sites...
http://acronis.com (True Image)
http://terabyteunlimited.com (Image for Window)
Old 12-22-2008   #3 (permalink)
Henson
This may sound rediculous, but..
Are there any imaging programs that allow you to save your drive image to
the exact same drive (but exclude images on that drive in future backups?)
I've used Ghost, but have trouble restoring an image from a network drive.
I'm using a laptop, and I won't want to exactly carry around a HD all the
time.
Thanks!
- Henson
<dev@xxxxxx> wrote in message
news:ul3h89HZJHA.728@xxxxxx
>> awhile ago.
>> shouldn't.
>> total.]
>> 1.66ghz duo cpu
Old 12-23-2008   #4 (permalink)
Richard Urban
Yes there are. You do it by exclusions.
But it is NEVER a good idea to backup the operating system to the same drive
that the operating system resides on.
Richard Urban
Microsoft MVP
Windows Desktop Experience
"Henson" <mrnull@xxxxxx> wrote in message
news:%23vHFTdKZJHA.4480@xxxxxx
> time.
> Thanks!
> - Henson
>>> awhile ago.
>>> shouldn't.
>>> total.]
>>> 1.66ghz duo cpu
Old 01-26-2009   #5 (permalink)
JOSEPH C HENDRICKS
YOU NOT HAVING LUCK ARE YOU
"MasterPenguin" <guest@xxxxxx-email.com> wrote in message
news:f0085c7d4c2976675efac46c2298f3af@xxxxxx-gateway.com...
> awhile ago.
> shouldn't.
> total.]
> 1.66ghz duo cpu
> MasterPenguin
System Restore Takes Forever to Open Vista General
Vista Installation taking forever General Discussion
System Restore - taking too long? General Discussion
Email is taking forever Vista mail
startup repair taking forever Vista General
