Preparing to install when click on start, recycle bin, etc.
Recently my system started having a problem where I would get a preparing to
install message when right clicking on the recycle bin, clicking on the start
button or starting applications like Word. It doesn't happen every time but
always happens the first time I do one of these after rebooting the computer.
I tried uninstalling Microsoft Office 2007 and then had to follow the
instructions in KB928218 for uninstalling when you cannot use add or remove
programs. I was not able to remove a few "groove" files because it said I
didn't have rights. (I am the administrator). I reinstalled but still have
the issue.
I have searched the internet and microsoft and have tried every reasonable
solution I have seen. It's getting on my nerves
If anyone has ideas on how to fix this I would greatly appreciate it.
Running Windows Vista Ultimate with all patches, Microsoft Office 2007
Enterprise with all patches.
Thanks.
Vista Ultimate SP2 x64 Windows 7 Ultimate x64 SP1
Local Time: 04:43 AM
Re: Preparing to install when click on start, recycle bin, etc.
the issue.
Thanks.
Hi caren,
Sometimes you have to right click on things and check run a s admin even if you're signed in as an admin. You might try running SFC to see if it helps any. Run a full malware scan with an antivirus program, just to be sure.
System Manufacturer/Model Number Airbot 2.0 OS Vista Ultimate SP2 x64 Windows 7 Ultimate x64 SP1 CPU Core i7 920 (D0) @ 4Ghz, 26c idle- 65c full load on air Motherboard Asus P6X58D Premium -Sata 6Gb/s - USB 3.0 Memory 12GB Corsair Dominator -CMD12GX3M6A1600C8 Graphics Card EVGA Nvidia GTX 480 -Fermi Sound Card ASUS Xonar D2X Monitor(s) Displays LG 24" Flatron W2453V-PF Full HD 1080p 2ms response time Screen Resolution 1920x1080@60hz
Keyboard Logitech Wireless MK700 Mouse Logitech Wireless MK700 PSU Corsair HX1000W Case Cooler Master HAF 932 Cooling Case Fans -3 230mm, 1 140mm/CPU - Tuniq Tower 120 Extreme Hard Drives 1 OCZ Vertex2 180GB SSD
Pioneer DVD Burner DVR-S18M Internet Speed 100 MBPS DL 30.17Mbps UL 0.98Mbps Other Info Windows 7
W.E.I final score= 7.7
Windows Vista=5.9
