| | network hard drive /usb drive hi,i have just baught a buffalo 500gb nas drive which has installed ok ,it has a usb port in the back so i can connect a usb hard drive,which i have done this seemed to work perfect until i tried to set up a auto backup to the usb drive .i keep on getting various eror messages ,"you do not have permission "or "network name cannot be found "or sometimes "backup failed due to a I/0 fault 0x8007045d .When the drive was installed it mapped itself as drive m and the usb as L but it also created a folder on the m drive called "usbdrive1" i have tried unmapping drive L and just using the folder that had been created but still cannot get any backups to work all i get is a series of empty temp folders .Can anyone give me any advise on setting up the drives or point me to a blog that will help. i am using vista h/p vista backup and restore buffalo500gb nas drive seagate 500gb usb drive any help will be appreciated thanks -- martyb |
| | RE: network hard drive /usb drive update:-ok i have now disconnected the mapped usb drive ,deleted the usb1 folder created in the share folder of the nas drive then re-formatted the usb drive using the utility in the web admin of the nas drive result is i can now do a full backup but all i get is empty temp folders 32approx which get added to every time i backup . If i map the usb drive then i don't have ownership of it so dont get any write permissions and cannot find any way to change it hope this has clarified things a bit -- martyb "marty" wrote: Quote: > hi,i have just baught a buffalo 500gb nas drive which has installed ok ,it > has a usb port in the back so i can connect a usb hard drive,which i have > done this seemed to work perfect until i tried to set up a auto backup to the > usb drive .i keep on getting various eror messages ,"you do not have > permission "or "network name cannot be found "or sometimes "backup failed due > to a I/0 fault 0x8007045d .When the drive was installed it mapped itself as > drive m and the usb as L but it also created a folder on the m drive called > "usbdrive1" i have tried unmapping drive L and just using the folder that had > been created but still cannot get any backups to work all i get is a series > of empty temp folders .Can anyone give me any advise on setting up the drives > or point me to a blog that will help. > i am using vista h/p > vista backup and restore > buffalo500gb nas drive > seagate 500gb usb drive > any help will be appreciated thanks > > -- > martyb |
| Hard drive light constantly flashing ,reading hard drive during id | Vista hardware & devices | |||
| re network hard drive | Vista networking & sharing | |||
| Crashed hard drive...copied hard drive but can't access User area | Vista General | |||
| Transferring files from Slave XP hard drive to new Vista Hard drive - primary | Vista installation & setup | |||
