| vista home premium 64 bit | power options don't work Just bought a new pc and everything is fine. I used the power option in control panel and set monitor off in 10 min and sleep in 15 in recommended settings. Nothing is working |
| Vista Ultimate SP2 x64 Windows 7 Ultimate x64 TECHNET | Re: power options don't work Maybe take a look at Brinks tutorials to see if anything can help. Power Options and Sleep Mode Problems Power Plan - Restore Default Settings |
| vista home premium 64 bit | Re: power options don't work Maybe take a look at Brinks tutorials to see if anything can help. Power Options and Sleep Mode Problems Power Plan - Restore Default Settings |
| Vista Ultimate SP2 x64 Windows 7 Ultimate x64 TECHNET | Re: power options don't work Maybe take a look at Brinks tutorials to see if anything can help. Power Options and Sleep Mode Problems Power Plan - Restore Default Settings Oh, ok. Glad you got it sorted. |
| vista home premium 64 bit | Re: power options don't work Thanks again,Brinks was the answer |
Power Options Corrupt (power plan unavailable) | General Discussion | |||
| Power options: Turn off hard disk doesn't work | General Discussion | |||
| vista power options no longer work? | Vista General | |||
| almost no power plan options work | Vista General | |||
| WOW! Screen saver and Power options work . . . at last! | Vista General | |||
