| | Problem with Vista on a Sony laptop... I close the lid and the laptop eventually goes into Sleep Mode. When I open the lid and Vista comes back up, I can no longer use the Windows shortcut where I can click on an item at the top of the list, hold down the shift key, and click on an item at the bottom to select everything in between. It doesn't work with the Control key either to let me select multiple items. The computer doesn't respond to the mouse click while I'm holding the shift key and then when I let the shift key up, the laptop beeps at me and won't let me move the mouse cursor for a few seconds. Rebootiing the laptop is the only way to fix it. I swapped emails with Sony tech support and they were worthless. I thought I'd try here, but I'm probably the only person on the planet with this problem. I haven't tried installing XP on this machine to see if it's a hardware problem, but that will be next if I get no replies. I'm trying really hard to like Vista. |
| | Re: Problem with Vista on a Sony laptop... It would be helpful to have some more details such as which version of Vista are you using. Do you have SP1 installed? What type of Sony notebook? Tyro "Kevinp" <kevinp@xxxxxx> wrote in message news:dd20m4po8p7lp97e5s4cj83jgbo42me80o@xxxxxx Quote: > I close the lid and the laptop eventually goes into Sleep Mode. When I > open the lid and Vista comes back up, I can no longer use the Windows > shortcut where I can click on an item at the top of the list, hold down > the shift key, and click on an item > at the bottom to select everything in between. It doesn't work with the > Control key either to let me select multiple items. The computer doesn't > respond to the mouse click while I'm holding the shift key and then when I > let the shift key up, the > laptop beeps at me and won't let me move the mouse cursor for a few > seconds. Rebootiing the laptop is the only way to fix it. > > I swapped emails with Sony tech support and they were worthless. I thought > I'd try here, but I'm probably the only person on the planet with this > problem. I haven't tried installing XP on this machine to see if it's a > hardware problem, but that will > be next if I get no replies. I'm trying really hard to like Vista. |
| | Re: Problem with Vista on a Sony laptop... Laptop is a Sony Vaio VGN-NS140E that my company purchased about six weeks ago from CompUSA. It came with Vista Home Premium with SP1. The "Vaio Care" crapware that came on it tells me there are no updates available. I have installed all the latest Windows updates. On Sat, 3 Jan 2009 17:56:27 -0800, "Tyro" <Tyro@xxxxxx> wrote: Quote: >It would be helpful to have some more details such as which version of Vista >are you using. Do you have SP1 installed? What type of Sony notebook? > >Tyro > >"Kevinp" <kevinp@xxxxxx> wrote in message >news:dd20m4po8p7lp97e5s4cj83jgbo42me80o@xxxxxx Quote: >> I close the lid and the laptop eventually goes into Sleep Mode. When I >> open the lid and Vista comes back up, I can no longer use the Windows >> shortcut where I can click on an item at the top of the list, hold down >> the shift key, and click on an item >> at the bottom to select everything in between. It doesn't work with the >> Control key either to let me select multiple items. The computer doesn't >> respond to the mouse click while I'm holding the shift key and then when I >> let the shift key up, the >> laptop beeps at me and won't let me move the mouse cursor for a few >> seconds. Rebootiing the laptop is the only way to fix it. >> >> I swapped emails with Sony tech support and they were worthless. I thought >> I'd try here, but I'm probably the only person on the planet with this >> problem. I haven't tried installing XP on this machine to see if it's a >> hardware problem, but that will >> be next if I get no replies. I'm trying really hard to like Vista. |
| | Re: Problem with Vista on a Sony laptop... I gave you the specs and you didn't bother to respond. We have words for people like you. On Sat, 3 Jan 2009 17:56:27 -0800, "Tyro" <Tyro@xxxxxx> wrote: Quote: >It would be helpful to have some more details such as which version of Vista >are you using. Do you have SP1 installed? What type of Sony notebook? > >Tyro > >"Kevinp" <kevinp@xxxxxx> wrote in message >news:dd20m4po8p7lp97e5s4cj83jgbo42me80o@xxxxxx Quote: >> I close the lid and the laptop eventually goes into Sleep Mode. When I >> open the lid and Vista comes back up, I can no longer use the Windows >> shortcut where I can click on an item at the top of the list, hold down >> the shift key, and click on an item >> at the bottom to select everything in between. It doesn't work with the >> Control key either to let me select multiple items. The computer doesn't >> respond to the mouse click while I'm holding the shift key and then when I >> let the shift key up, the >> laptop beeps at me and won't let me move the mouse cursor for a few >> seconds. Rebootiing the laptop is the only way to fix it. >> >> I swapped emails with Sony tech support and they were worthless. I thought >> I'd try here, but I'm probably the only person on the planet with this >> problem. I haven't tried installing XP on this machine to see if it's a >> hardware problem, but that will >> be next if I get no replies. I'm trying really hard to like Vista. |
| | Re: Problem with Vista on a Sony laptop... On Sun, 11 Jan 2009 16:16:35 -0500, Kevinp <kevinp@xxxxxx> wrote: Quote: >I gave you the specs and you didn't bother to respond. We have words for people like you. useless... OR "Tyro" didn't have a clue what to do with it once you provided it. Probably the latter. Quote: > >On Sat, 3 Jan 2009 17:56:27 -0800, "Tyro" <Tyro@xxxxxx> wrote: > Quote: >>It would be helpful to have some more details such as which version of Vista >>are you using. Do you have SP1 installed? What type of Sony notebook? >> >>Tyro >> >>"Kevinp" <kevinp@xxxxxx> wrote in message >>news:dd20m4po8p7lp97e5s4cj83jgbo42me80o@xxxxxx Quote: >>> I close the lid and the laptop eventually goes into Sleep Mode. When I >>> open the lid and Vista comes back up, I can no longer use the Windows >>> shortcut where I can click on an item at the top of the list, hold down >>> the shift key, and click on an item >>> at the bottom to select everything in between. It doesn't work with the >>> Control key either to let me select multiple items. The computer doesn't >>> respond to the mouse click while I'm holding the shift key and then when I >>> let the shift key up, the >>> laptop beeps at me and won't let me move the mouse cursor for a few >>> seconds. Rebootiing the laptop is the only way to fix it. >>> >>> I swapped emails with Sony tech support and they were worthless. I thought >>> I'd try here, but I'm probably the only person on the planet with this >>> problem. I haven't tried installing XP on this machine to see if it's a >>> hardware problem, but that will >>> be next if I get no replies. I'm trying really hard to like Vista. |
| | #6 (permalink) |
| | Re: Problem with Vista on a Sony laptop... "Kevinp" <kevinp@xxxxxx> wrote in message news:ubokm49q1618n1pvikscm9unmqdaok1vm8@xxxxxx Quote: >I gave you the specs and you didn't bother to respond. We have words for >people like you. a driver for Sony hardware. HTH -pk Quote: > > On Sat, 3 Jan 2009 17:56:27 -0800, "Tyro" <Tyro@xxxxxx> wrote: > Quote: >>It would be helpful to have some more details such as which version of >>Vista >>are you using. Do you have SP1 installed? What type of Sony notebook? >> >>Tyro >> >>"Kevinp" <kevinp@xxxxxx> wrote in message >>news:dd20m4po8p7lp97e5s4cj83jgbo42me80o@xxxxxx Quote: >>> I close the lid and the laptop eventually goes into Sleep Mode. When I >>> open the lid and Vista comes back up, I can no longer use the Windows >>> shortcut where I can click on an item at the top of the list, hold down >>> the shift key, and click on an item >>> at the bottom to select everything in between. It doesn't work with the >>> Control key either to let me select multiple items. The computer doesn't >>> respond to the mouse click while I'm holding the shift key and then when >>> I >>> let the shift key up, the >>> laptop beeps at me and won't let me move the mouse cursor for a few >>> seconds. Rebootiing the laptop is the only way to fix it. >>> >>> I swapped emails with Sony tech support and they were worthless. I >>> thought >>> I'd try here, but I'm probably the only person on the planet with this >>> problem. I haven't tried installing XP on this machine to see if it's a >>> hardware problem, but that will >>> be next if I get no replies. I'm trying really hard to like Vista. |
| | #7 (permalink) |
| | Re: Problem with Vista on a Sony laptop... That was my first thought also and why I tried contacting Sony. Apparently they're too big a company to care and I guess I'm the only one having this problem... On Sun, 11 Jan 2009 18:40:11 -0500, "Patrick Keenan" <test@xxxxxx> wrote: Quote: > >"Kevinp" <kevinp@xxxxxx> wrote in message >news:ubokm49q1618n1pvikscm9unmqdaok1vm8@xxxxxx Quote: >>I gave you the specs and you didn't bother to respond. We have words for >>people like you. >Regardless, that's likely something that Sony, not Microsoft, has to fix in >a driver for Sony hardware. > >HTH >-pk > > Quote: >> >> On Sat, 3 Jan 2009 17:56:27 -0800, "Tyro" <Tyro@xxxxxx> wrote: >> Quote: >>>It would be helpful to have some more details such as which version of >>>Vista >>>are you using. Do you have SP1 installed? What type of Sony notebook? >>> >>>Tyro >>> >>>"Kevinp" <kevinp@xxxxxx> wrote in message >>>news:dd20m4po8p7lp97e5s4cj83jgbo42me80o@xxxxxx >>>> I close the lid and the laptop eventually goes into Sleep Mode. When I >>>> open the lid and Vista comes back up, I can no longer use the Windows >>>> shortcut where I can click on an item at the top of the list, hold down >>>> the shift key, and click on an item >>>> at the bottom to select everything in between. It doesn't work with the >>>> Control key either to let me select multiple items. The computer doesn't >>>> respond to the mouse click while I'm holding the shift key and then when >>>> I >>>> let the shift key up, the >>>> laptop beeps at me and won't let me move the mouse cursor for a few >>>> seconds. Rebootiing the laptop is the only way to fix it. >>>> >>>> I swapped emails with Sony tech support and they were worthless. I >>>> thought >>>> I'd try here, but I'm probably the only person on the planet with this >>>> problem. I haven't tried installing XP on this machine to see if it's a >>>> hardware problem, but that will >>>> be next if I get no replies. I'm trying really hard to like Vista. |
| | #8 (permalink) |
| | Re: Problem with Vista on a Sony laptop... Yes, probably the latter ![]() On Sun, 11 Jan 2009 17:31:34 -0600, Addison Steele <addisonsteele@xxxxxx> wrote: Quote: >On Sun, 11 Jan 2009 16:16:35 -0500, Kevinp <kevinp@xxxxxx> wrote: > Quote: >>I gave you the specs and you didn't bother to respond. We have words for people like you. >"Tyro" must've realized that the info that was asked for was >useless... OR "Tyro" didn't have a clue what to do with it once you >provided it. > >Probably the latter. > Quote: >> >>On Sat, 3 Jan 2009 17:56:27 -0800, "Tyro" <Tyro@xxxxxx> wrote: >> Quote: >>>It would be helpful to have some more details such as which version of Vista >>>are you using. Do you have SP1 installed? What type of Sony notebook? >>> >>>Tyro >>> >>>"Kevinp" <kevinp@xxxxxx> wrote in message >>>news:dd20m4po8p7lp97e5s4cj83jgbo42me80o@xxxxxx >>>> I close the lid and the laptop eventually goes into Sleep Mode. When I >>>> open the lid and Vista comes back up, I can no longer use the Windows >>>> shortcut where I can click on an item at the top of the list, hold down >>>> the shift key, and click on an item >>>> at the bottom to select everything in between. It doesn't work with the >>>> Control key either to let me select multiple items. The computer doesn't >>>> respond to the mouse click while I'm holding the shift key and then when I >>>> let the shift key up, the >>>> laptop beeps at me and won't let me move the mouse cursor for a few >>>> seconds. Rebootiing the laptop is the only way to fix it. >>>> >>>> I swapped emails with Sony tech support and they were worthless. I thought >>>> I'd try here, but I'm probably the only person on the planet with this >>>> problem. I haven't tried installing XP on this machine to see if it's a >>>> hardware problem, but that will >>>> be next if I get no replies. I'm trying really hard to like Vista. |
| Problem with Sony Laptop (VISTA) | Drivers | |||
| Problem upgrading to Vista on Sony Vaio laptop | Vista General | |||
| Upgrading a Sony Laptop to Vista Ultimate | Vista General | |||
| Laptop Sony with windows Vista | Vista networking & sharing | |||
| audio problem with my sony vaio laptop and x64 problem | Vista hardware & devices | |||
