| | Mobile Device Center Changes Device ID I've just attempted to switch from XP to Vista. I have an iPaq6925 with Windows Mobile 5 installed and several third party applications. After a day of wrangling with it, I've discoverd that the WMDC seems to be changing the Device ID from what I made it to WINDOWSMOBILEXX every time I sync. This totally disables my third part software and for my application, makes the mobile device worthless. On the WMDC control panel it properly refers to my device by it's "given" name and says it is partnered with it, but every time I sync, the third party programs either lock up or tell me they will only work on device named "given name". I'm ready to pitch the thing out the window. I've seen several other posts on the web about this problem, but no fixes. Ideas please? |
| Manually remove device from mobile device center. | Vista General | |||
| Windows Mobile Device Center randomly fails to recognize device | Vista General | |||
| Mobile Device Center changes device id every sync .. breaks apps | Vista General | |||
| T-Mobile Dash sync problems with Windows Mobile Device Center | Vista hardware & devices | |||
| windows mobile device center - device only connects on one USB por | Vista hardware & devices | |||
