| Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks. |
| | LinkBack | Thread Tools | Display Modes |
| Guest | Quicken 2009 PDF printer problem- mistake or intentional? It appears right now that in order to get the Quicken 2009 PDF printer to work in Vista, you have to run the program in administrator mode. Since this software was released after Vista, might this problem be the result of SP1, or bad programming, or possibly intentional for some specific reason? Thanks, Clark |
| | #2 (permalink) | ||||||||||||
| Guest | Re: Quicken 2009 PDF printer problem- mistake or intentional? On Jan 5, 9:05*am, "Clark" <no-s...@xxxxxx> wrote:
My System Specs![]() | |||||||||||||
| | #3 (permalink) | ||||||||||||
| Guest | Re: Quicken 2009 PDF printer problem- mistake or intentional? "MikeB" <MPBrede@xxxxxx> wrote in message news:1bad0a29-44b3-4e01-aef1-0014652a845c@xxxxxx On Jan 5, 9:05 am, "Clark" <no-s...@xxxxxx> wrote:
No, this forum would have a better idea of the programming issues. Clark | ||||||||||||
| | #4 (permalink) | ||||||||||||||||||||||||
| Guest | Re: Quicken 2009 PDF printer problem- mistake or intentional? "Clark" <no-spam@xxxxxx> wrote in message news:F8B53F43-3806-4D78-BD53-A5930A2EE212@xxxxxx
So, you're saying that Vista must be bad because Quicken 2009 PDF printer doesn't work correctly? You're one of the reasons that the Movie "Idiocracy" is so prophetic, and you've made my filter pack. | ||||||||||||||||||||||||
My System Specs![]() | |||||||||||||||||||||||||
| | #5 (permalink) | ||||||||||||||||||||||||||||||||||||
| Guest | Re: Quicken 2009 PDF printer problem- mistake or intentional? "Sinner" <sinner@xxxxxx> wrote in message news:bHq8l.2879$3y5.2068@xxxxxx
Vista, but why a company would put out a program that does not work with Vista more than a year after it was released.. Oh well -- Clark | ||||||||||||||||||||||||||||||||||||
My System Specs![]() | |||||||||||||||||||||||||||||||||||||
| | #6 (permalink) |
| Newbie | Re: Quicken 2009 PDF printer problem- mistake or intentional? I suspect the problem has the same root that was in Quicken 2008. They used the 3.0 PDF engine and it was not compatible with Vista 64 bit. I spend more than three months trying to ferret out the issues with both Microsoft and Intuit. It appears Intuit does not care about the 64 bit version of Vista. I invested many, many hours investigating this problem. Ultimately, had to go to Microsoft Money, but they are way behind Intuit in functionality. |
| | #7 (permalink) | ||||||||||||
| Guest | Re: Quicken 2009 PDF printer problem- mistake or intentional? bobbrandenburg wrote:
the program to "Run as Administrator". Not if being run by a standard user or administrator/user. I wish I could find out what the difference was between Running as Administrator and running from a user/administrator account. All my other printers work normally, but I do have an HP printer. Clark | ||||||||||||
| | #8 (permalink) | ||||||||||||||||||||||||
| Guest | Re: Quicken 2009 PDF printer problem- mistake or intentional? Clark wrote:
It appears starting Quicken from the Start Menu or Quick Lauch, or by double clicking on the qw.exe file will not allow the PDF Printer to function correctly. Solution is to use a Desktop shortcut to start the program and make sure there is nothing in the Properties-General "Start in: " box. If you do not have a desktop shortcut, the easiest way is to go to Start Menu and right click on the Quicken starter and select "Send to Desktop". This should stop the errors where the PDF printer appears to not be accessible. Maybe it will help with the others also. Clark | ||||||||||||||||||||||||
| | #9 (permalink) | ||||||||||||
| Newbie | Re: Quicken 2009 PDF printer problem- mistake or intentional? [quote=Clark;944478]Clark wrote:
PowderCreek | ||||||||||||
| Display Modes | |
| WLM 2009 Build 14.0.8050.12.02 Problem | Henry Fitzroy | Live Messenger | 1 | 12-19-2008 04:00 PM |
| Problem with WLM 2009 Beta | XecteD | Live Messenger | 1 | 12-18-2008 10:50 PM |
| Vista 64, Quicken Billminder problem. | XS11E | Vista General | 3 | 11-13-2008 08:39 AM |
| "quicken background agent" / "quicken scheduled updates" blocked in Vista Options | markm75 | Vista security | 0 | 06-15-2007 08:10 PM |
| Anyone using Pocket Quicken 2.5, Quicken 2007 and Vista? | lawsce | Vista General | 0 | 02-07-2007 09:40 AM |
