Vista Forums Home Join Vista Forums Tech Publications Windows 7 Forum Vista Tutorials Webcasts Tags
Welcome to Vista Forums we are your forum for Windows Vista help and discussion. Whether you need help or just want to post an idea you have on Vista, this is the forum for you.
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Shut down VS 'low power state'
Update your Vista Drivers
Thread Tools Display Modes
Old 10-02-2006   #1 (permalink)
=?Utf-8?B?dGhianIocmVtb3ZldGhpcylAaG90bWFpbC5jb20=?=
Guest
On my laptop, in XP, when I pressed the power button, the computer would shut
down. With Vista, when I press the power button, the computer goes into a
'low power state' mode. How do I get it to wake up from this low power state?
I tried the power button, no good. Tried pressing keys, movind the mouse, no
good. Only way I could get the computer working again was to press and hold
the power button until it crashed and then restart.
By the way, my power button has the same symbol on it as the symbol left of
the 'lock' symbol to lock the computer in the shut down line on the Vista
start menu. Is the only way to turn off this computer now to go into the
start menu, then to the shutdown/restart/hibernate menu and click on shut
down, like in versions of Windows before XP?
Suggestions on powering up from 'low power state' mode and alternate shut
down options would be welcome.
Thanks, Tom
Old 10-02-2006   #2 (permalink)
=?Utf-8?B?R2VuZSBGaXR6?=
Guest
RE: Shut down VS 'low power state'
I have a laptop as well. I did the standby (low power) thing once, but all I
had to do, was press the power button once, and it woke right up.
> Thanks, Tom
Old 10-02-2006   #3 (permalink)
Guest
One more thought thouh, you can go into power settings and set it up to when
you press the power button it goes to auto shutdown. On the bottom right,
just right click on the battery and cable. you can also make adjustments to
what to do when you close the lid and such.
I have mine in an "Always on" configuration,, and have it set up to go to
shut down when I push the power button..
Hope that helps..
> Thanks, Tom
Old 10-02-2006   #4 (permalink)
Guest
Thanks, I've changed the settings as suggested and that worked for sutting it
down. Wish I knew why it won't wake up.
Thanks!
> Hope that helps..
> > Thanks, Tom
Display Modes
low power state speedy_rudolf Vista General 0 12-09-2007 10:03 AM
USB Hub power state NOT sticking Michael Tissington Vista hardware & devices 0 09-20-2007 07:46 PM
Problem using Low Power State BlueNightmare Vista file management 2 07-15-2007 09:43 AM
low power state Dreamlover Vista performance & maintenance 1 04-18-2007 11:15 AM
Shut Down vs 'low power state' =?Utf-8?B?dGhianIocmVtb3ZldGhpcylAaG90bWFpbC5jb20=?= Vista General 0 10-02-2006 06:46 PM
Complimentary Industry Resources
Vista Forums has joined forces with TradePub.com to offer you a new, exciting, and entirely free professional resource. Visit http://vistax64.tradepub.com today to browse our selection of complimentary Industry magazines, white papers, webinars, podcasts, and more across 34 industry sectors. No credit cards, coupons, or promo codes required. Try it today!
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
