| | Sound not working after resuming from Sleep Mode So as the title says it, there is no sound whatsoever after my computer awakens from sleep mode. the system is working perfectly fine, just that I can't hear any sounds (i've checked my mute and volume settings, they were all turned up to the max). I'm thinking this might be related with my computer's sound driver not being properly installed.. |
| | Re: Sound not working after resuming from Sleep Mode "pmajin" wrote > So as the title says it, there is no sound whatsoever after my computer > awakens from sleep mode. the system is working perfectly fine, just that I > can't hear any sounds (i've checked my mute and volume settings, they were > all turned up to the max). I'm thinking this might be related with my > computer's sound driver not being properly installed.. What sound device and driver? Is it the XP driver or a Vista driver? -- Rock [ MVP User/Shell] |
| No sound after resuming from sleep mode | Sound & Audio | |||
| ATI: Drivers are interfering with Windows resuming from sleep mode | Vista hardware & devices | |||
| Taskbar missing after resuming from sleep mode | Vista installation & setup | |||
| Losing Internet connection when resuming from sleep-mode | Vista General | |||
| Issue resuming Sleep Mode | Vista hardware & devices | |||
