| Vista Home Premium x64 | Usb "connection terminated" HI, I installed a USM Modem and a Huawei E226 USB Mobile broadband modem. They all come with Vista x64 drivers. I do see them as installed on the device manager; but when I use their respective programs: a) Mobile Partner (for the Huawei broadband modem), it appears "Connection terminated" and "cannot find a phone-book entry". b) Ipass roaming (for the USB Modem) or I'm trying to create a dial-up connection. When I try to use the USB Modem, it says that there's no modem available to create a dial up Connection. With the Ipass it doesn't show the modem on installed devices to use. I don't know what's happenning, but I'm getting crazy. For your information, either the USB Modem and/or the Huawei E226 worked perfectly on any other computer running Windows XP. Can anyone help me with thi issue or if you know how to solve it, I would appreciate it. I am running Windows Vista Hope Premium x86 64 bits. Thanks in advance. |
| Unwanted Multiple contacts in "To","CC","BCC" of email send catago | Vista mail | |||
| Vista not wotking with "My Computer" or "Control Panel", "Screen Saver" | Vista General | |||
| "host process terminated" at resume | Vista General | |||
| How can I add the icons "Delete", "Cut", "Copy" and "Paste" in Vis | Vista file management | |||
| WM5 Sync with Vista "Windows Calender", "Contacts", and "Mail" | Vista General | |||
