| | RC1 search box in start menu is not removed when made selection Hello, I am running RC1. I can't make the search box in the start menu to disappear. I was able to do this in Beta2 by choosing choosing properties after right click on start bottem and then choose customize ... then remove the check mark from search. This did not remove the search box. I even tried to remove the check marks from all the serach options there .. Any reason why this does not work for me in RC1? I would be better if an option like this is provided by simply right click on the check box area to enable/disble this option. Please let me know if you what the problem is. This unnecessary feature prevent me from using key strokes with the start menu efficiently. Thanks, Shawn |
| | Re: RC1 search box in start menu is not removed when made selection "Shawn" wrote > Hello, I am running RC1. > I can't make the search box in the start menu to disappear. > I was able to do this in Beta2 by choosing choosing properties after right > click on start bottem and then choose customize ... then remove the check > mark from search. This did not remove the search box. I even tried to > remove > the check marks from all the serach options there .. > Any reason why this does not work for me in RC1? > > I would be better if an option like this is provided by simply right click > on the check box area to enable/disble this option. > > Please let me know if you what the problem is. > This unnecessary feature prevent me from using key strokes with the start > menu efficiently. Look through the group policies to see if there is a way to disable the search display. Run as administrator, gpedit.msc. -- Rock [ MVP User/Shell] |
| Replace Start Menu Search with 3rd Party Search | General Discussion | |||
| Vista SP1 removed the Search shortcut from the Start Panel | Vista General | |||
| SP1 Removed The Search Button From The Start Menu - How Can I Rest | Vista performance & maintenance | |||
| uninstalled progs not being removed from start menu | Vista General | |||
| Changing Start Menu Search default selection from "Search the Com. | Vista file management | |||
