Vista - print issue
Old 01-09-2009   #1 (permalink)
dconrad
print issue
Have a HP 1700d printer -- d is for duplex, however, in vista cannot find option to print on both sides -- no problem if run on xp.  Note this is a network printer running on an xp machine. Thanks
Old 01-09-2009   #2 (permalink)
Richard G. Harper [MVP]
Re: print issue
Have you checked with HP for Vista drivers? Most likely you will need to
install the Vista drivers on your computer (not the XP computer) and then
make the network connection to the XP computer.
Richard G. Harper [MVP Desktop] rgharper@xxxxxx
* NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/
* PLEASE post all messages and replies in the newsgroups
* The Website - http://rgharper.mvps.org/
<dconrad@xxxxxx> wrote in message
news:uFvcxjpcJHA.552@xxxxxx
print issue-x32 lap to x64 desktop Drivers
Vista Duplex Print Issue with IE7 Vista General
Vista print issue with Creatfile() Vista print fax & scan
HP C6180 C7180 print issue Vista print fax & scan
MS Publisher Print Layout Issue Vista print fax & scan
