Vista - vista 32: problem adding to explorer context menu
Old 01-16-2009   #1 (permalink)
Paul
Is there a fix for this it looks unresolved:
http://groups.google.com/group/micro...737432671263bf
I can't add a context menu item to register dlls. None of the registry
edits are working for me.
Old 01-16-2009   #2 (permalink)
Paul
Re: vista 32: problem adding to explorer context menu
ocx and exe will show the context menu item, but I can't set this up for
dlls, doesn't work.
-------- Original Message --------
Old 01-16-2009   #3 (permalink)
Paul
I think I fixed this by removing these 2 keys.
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.dll\OpenWithList
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.dll\UserChoice
I had an application defined to open dlls (red gate reflector).
Now my context menu items appear.
> dlls, doesn't work.
Solved re-order windows explorer context menu General Discussion
Windows Explorer Context Menu - How to? General Discussion
adding context menu items thru regedit Vista file management
Explorer Context Menu Vista General
Context menu item problem in Vista Vista General
