| 32bit | Vista Sound Recorder problem Hello All, I have a problem with my sound recorder on Vista. First, I was disappointed with the new sound recorder, I needed to edit the sound files for my projects, and as far as I knew, that was not a ability with the new one. So I downloaded the old XP one. It was just a straight .exe file. I ran it and of course I got the standard permission message. The message warned me that it was a registry editor. I ran it and after, I lost the ability to record and talk on my computer. Is there a fix? Thanks, - CP |
| | Re: Vista Sound Recorder problem Where did you download the recorder from? -- David C. Microsoft Certified Trainer http://www.heroescertificados.com "ConstantPhoenix" <guest@xxxxxx-email.com> escribió en el mensaje de noticias:fae0a57376755af8609d75bce60a589f@xxxxxx-gateway.com... Quote: > > Hello All, > > I have a problem with my sound recorder on Vista. > > First, I was disappointed with the new sound recorder, I needed to edit > the sound files for my projects, and as far as I knew, that was not a > ability with the new one. So I downloaded the old XP one. It was just a > straight .exe file. I ran it and of course I got the standard permission > message. The message warned me that it was a registry editor. I ran it > and after, I lost the ability to record and talk on my computer. > > Is there a fix? Thanks, > > - CP > > > -- > ConstantPhoenix |
| 32bit | Re: Vista Sound Recorder problem Where did you download the recorder from? -- David C. Microsoft Certified Trainer { Héroes Certificados } "ConstantPhoenix" <guest@xxxxxx-email.com> escribió en el mensaje de noticias:fae0a57376755af8609d75bce60a589f@xxxxxx-gateway.com... Quote: > > Hello All, > > I have a problem with my sound recorder on Vista. > > First, I was disappointed with the new sound recorder, I needed to edit > the sound files for my projects, and as far as I knew, that was not a > ability with the new one. So I downloaded the old XP one. It was just a > straight .exe file. I ran it and of course I got the standard permission > message. The message warned me that it was a registry editor. I ran it > and after, I lost the ability to record and talk on my computer. > > Is there a fix? Thanks, > > - CP > > > -- > ConstantPhoenix What I think happend is that it edited the registry, and replaced some type of file with an outdated or corrupted one. Any thoughts. Any help is greatly appreciated. - CP |
| | RE: Vista Sound Recorder problem Are you able to use System Restore to a time and date prior to the occurrence of the problem? "ConstantPhoenix" wrote: Quote: > > Hello All, > > I have a problem with my sound recorder on Vista. > > First, I was disappointed with the new sound recorder, I needed to edit > the sound files for my projects, and as far as I knew, that was not a > ability with the new one. So I downloaded the old XP one. It was just a > straight .exe file. I ran it and of course I got the standard permission > message. The message warned me that it was a registry editor. I ran it > and after, I lost the ability to record and talk on my computer. > > Is there a fix? Thanks, > > - CP > > > -- > ConstantPhoenix > |
| 32bit | Re: Vista Sound Recorder problem Are you able to use System Restore to a time and date prior to the occurrence of the problem? "ConstantPhoenix" wrote: Quote: > > Hello All, > > I have a problem with my sound recorder on Vista. > > First, I was disappointed with the new sound recorder, I needed to edit > the sound files for my projects, and as far as I knew, that was not a > ability with the new one. So I downloaded the old XP one. It was just a > straight .exe file. I ran it and of course I got the standard permission > message. The message warned me that it was a registry editor. I ran it > and after, I lost the ability to record and talk on my computer. > > Is there a fix? Thanks, > > - CP > > > -- > ConstantPhoenix > - CP |
| | #6 (permalink) |
| | Re: Vista Sound Recorder problem System Restore would not affect any files or data that you created. It only puts back the system itself. But if you installed any new applications, these would probably have to be reinstalled, and if the restoration date is prior to any Windows updates, these would have to be downloaded a second time. If you try it let us know how you get on. "ConstantPhoenix" wrote: Quote: > > Tony UK;942806 Wrote: Quote: > > Are you able to use System Restore to a time and date prior to the > > occurrence > > of the problem? > > > > "ConstantPhoenix" wrote: Quote: > > > > > > > > > > > > > Hello All, > > > > > > > > I have a problem with my sound recorder on Vista. > > > > > > > > First, I was disappointed with the new sound recorder, I needed to > > > edit > > > > the sound files for my projects, and as far as I knew, that was not a > > > > ability with the new one. So I downloaded the old XP one. It was just > > > a > > > > straight .exe file. I ran it and of course I got the standard > > > permission > > > > message. The message warned me that it was a registry editor. I ran > > > it > > > > and after, I lost the ability to record and talk on my computer. > > > > > > > > Is there a fix? Thanks, > > > > > > > > - CP > > > > > > > > > > > > -- > > > > ConstantPhoenix > > > > > > > No, would that delete all the programs and files that I've recently > installed and programed? > > - CP > > > -- > ConstantPhoenix > |
| | #7 (permalink) |
| 32bit | Re: Vista Sound Recorder problem System Restore would not affect any files or data that you created. It only puts back the system itself. But if you installed any new applications, these would probably have to be reinstalled, and if the restoration date is prior to any Windows updates, these would have to be downloaded a second time. If you try it let us know how you get on. "ConstantPhoenix" wrote: Quote: > > Tony UK;942806 Wrote: Quote: > > Are you able to use System Restore to a time and date prior to the > > occurrence > > of the problem? > > > > "ConstantPhoenix" wrote: > No, would that delete all the programs and files that I've recently > installed and programed? > > - CP > > > -- > ConstantPhoenix > |
| | #8 (permalink) |
| | Re: Vista Sound Recorder problem "ConstantPhoenix" <guest@xxxxxx-email.com> wrote in message news:dc11872549896c8f285c8dc09b9b584c@xxxxxx-gateway.com... Quote: > > Would a possible fix be to just download the current Vista Sound > recorder? Maybe If I could do that it would reinstall the old files and > possibly fix it. > > > -- > ConstantPhoenix Running the Xp version would not have deleted the Vista file. |
| | #9 (permalink) |
| 32bit | Re: Vista Sound Recorder problem "ConstantPhoenix" <guest@xxxxxx-email.com> wrote in message news:dc11872549896c8f285c8dc09b9b584c@xxxxxx-gateway.com... Quote: > > Would a possible fix be to just download the current Vista Sound > recorder? Maybe If I could do that it would reinstall the old files and > possibly fix it. > > > -- > ConstantPhoenix Running the Xp version would not have deleted the Vista file. |
| Sound Recorder In Vista | Vista General | |||
| Vista vs. XP Sound Recorder | Sound & Audio | |||
| Recording Problem with sound recorder | Vista music pictures video | |||
| Vista Sound Recorder Does Not Record | Vista General | |||
| Windows Vista Sound Recorder | Vista music pictures video | |||
