| Vista home basic | need PCI Card or USB for N Router to work with Vista Home Basic... i have a PCI G wireless card in my desktop with Vista Home Basic and it keeps dropping my wireless connection or it gets a weak signal. I'm only about 20 ft from the router. However, it sometimes picks up my neighbors network. Anyone out there can recommend either a USB or another PCI card that has Vista drivers and works with a Linksys N router? thanking you in advance. |
| | Re: need PCI Card or USB for N Router to work with Vista Home Basic... Try using a different channel that your router broadcasts on. "snowpak" <guest@xxxxxx-email.com> wrote in message news:b8b6a0c60104ffd3ddd489358bd38170@xxxxxx-gateway.com... Quote: > > i have a PCI G wireless card in my desktop with Vista Home Basic and it > keeps dropping my wireless connection or it gets a weak signal. I'm only > about 20 ft from the router. However, it sometimes picks up my neighbors > network. > Anyone out there can recommend either a USB or another PCI card that > has Vista drivers and works with a Linksys N router? > thanking you in advance. > > > -- > snowpak |
| Vista home basic | Re: need PCI Card or USB for N Router to work with Vista Home Basic... how do i change "the channel" of the broadcast? |
| | Re: need PCI Card or USB for N Router to work with Vista Home Basic... On Wed, 21 Jan 2009 09:12:30 -0600, snowpak <guest@xxxxxx-email.com> wrote: Quote: > >how do i change "the channel" of the broadcast? the default user name is blank and the password is "password". On the Wireless page, change the "channel". Choose 1, 6, or 11. Note that when you click "Save Settings" that you will be disconnected since you just changed the channel you were hooked up on. So, when the browser give you an error, it's OK to ignore it. The only way to see a "successful" page is to do it from a hard wired system. Reboot, or if you are up for it, disable/enable the wireless card in Device Manager. See how it works after that. |
| LAN Network Card (Drivers not Installed) Need Windows Vista Home Basic Drivers | Vista hardware & devices | |||
| USB jump drive on Vista Home Basic won't work | Vista hardware & devices | |||
| Vista Home Basic Video Card advice | Vista hardware & devices | |||
| Vista Home premium installed - then no basic tasks work | Vista installation & setup | |||
| Got Aero to work in Vista Home Basic !! | Vista General | |||
