| | Monitors won't go to power down after 30 minutes? I've tried everything and still my monitors won't go to power down, I have turn off display set to 25 minutes and I can leave go to work come back in 9 hours and the screen saver has kicked in but the monitors are still powered. What else can I check to get these to go to power savings mode? Thanks for any help, Rich |
| | RE: Monitors won't go to power down after 30 minutes? Hi Rich, what did you actually tried to do, so I can start from something ![]() -- MCSA, MCDST, MCP, MCTS, MCITP http://www.wincert.net "Rich" wrote: Quote: > I've tried everything and still my monitors won't go to power down, I have > turn off display set to 25 minutes and I can leave go to work come back in 9 > hours and the screen saver has kicked in but the monitors are still powered. > What else can I check to get these to go to power savings mode? > > Thanks for any help, Rich > > > > |
| | Re: Monitors won't go to power down after 30 minutes? I went to power options and chose a differnt number of minutes to put the monitors to sleep. If I set it for a minute and then sit there it works as expected, but I set it to 30 minutes and it stays on. Rich "N1K" <N1K@xxxxxx> wrote in message news:37A6F1AD-2535-44A6-8CB1-E2A141A74E65@xxxxxx Quote: > Hi Rich, > > what did you actually tried to do, so I can start from something ![]() > -- > MCSA, MCDST, MCP, MCTS, MCITP > http://www.wincert.net > > > "Rich" wrote: > Quote: >> I've tried everything and still my monitors won't go to power down, I >> have >> turn off display set to 25 minutes and I can leave go to work come back >> in 9 >> hours and the screen saver has kicked in but the monitors are still >> powered. >> What else can I check to get these to go to power savings mode? >> >> Thanks for any help, Rich >> >> >> >> |
| Monitors won't go to power off all the time | Vista General | |||
| settings changed - 3 monitors - maximises window across all 3 monitors instead of 1 | Vista installation & setup | |||
| 4 monitors ok, 5 monitors crashes media player, all video apps | Vista music pictures video | |||
| Vista Offline Files Consuming 100% CPU for 2 minutes every few minutes | Vista General | |||
| Monitors will not standby or power down after specified idle perio | Vista performance & maintenance | |||
