Vista - Contacts folder keep changing view style
Old 01-23-2009   #1 (permalink)
TheDuck
Daily I am having to change the style/layout of this folder to 'Contacts'
template.
An then, as if by magic, it will revert back to 'All Items' over-night....!
How can I fix the default to keep contacts view?
Thanks, Chris
Old 01-24-2009   #2 (permalink)
Dave
Re: Contacts folder keep changing view style
You might try the fix here...
Windows Explorer Folder View settings
Windows 7 beta
http://get.live.com/wlmail/overview
http://download.live.com/wlmail
"TheDuck" <chris33@xxxxxx> wrote in message
news:#ZbM1adfJHA.4728@xxxxxx
> template.
> over-night....!
> Thanks, Chris
Solved Changing folder View when Opening a File General Discussion
folder view keeps changing General Discussion
Re: Folder view keeps changing Vista performance & maintenance
Folder view keeps changing Vista file management
Folder view keeps changing Vista General
