Vista - Why does a fresh Vista installation create a partition at LBA 2048 ?
Old 01-24-2009   #1 (permalink)
Default User
XP created partitions that were aligned by cylinders, or in the case of the
first cylinder, it would skip the mbr track.
I just did a vista install and it decided to create the partition at LBA
2048. Not cylinder aligned anymore, and it skipped 2048 sectors. Any idea
why? Any links to information about this?
Thanks,
Alan
Old 01-25-2009   #2 (permalink)
Tyro
Re: Why does a fresh Vista installation create a partition at LBA 2048 ?
Vista does things differently from XP. I some cases, to keep the bad people
off guard.
Tyro
"Default User" <nospam38925@xxxxxx> wrote in message
news:0007729c$0$32660$c3e8da3@xxxxxx
Quote:
> Hi,
> the first cylinder, it would skip the mbr track.
> idea why? Any links to information about this?
> Thanks,
> Alan
fresh clean Vista Installation FAILURE General Discussion
I can't update, : Fresh vista installation. Windows Updates
Vista Crash/Freeze from fresh installation -_-;; Vista General
horribly slow x64 Vista on existing installation and on fresh ones Vista General
Lan Not Recognized in Vista Ultimate - Fresh Installation Vista hardware & devices
