Vista - Battery maximum charge percentage
Old 01-25-2009   #1 (permalink)
Rajesh A
My laptop battery is not charging up to 100%. It is charging up to 53% only.
I brought this laptop 1 year back and since 1 week I am facing this problem.
How to set battery maximum charge percentage in vista? Can any one help me
Thanks
Rajesh A
Old 01-25-2009   #2 (permalink)
Richard G. Harper
Re: Battery maximum charge percentage
Batteries only have so many charge/discharge cycles before they start losing
capacity. Check with your laptop manufacturer to see if they have a
recommended program or process for trying to recover battery capacity. If
they do not, or they have a process and it fails, then the battery may
simply be ready to be replaced.
Richard G. Harper [MVP Desktop] rgharper@xxxxxx
* NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/
* PLEASE post all messages and replies in the newsgroups
* The Website - http://rgharper.mvps.org/
"Rajesh A" <rajeshaz09@xxxxxx> wrote in message
news:FE92F4A8-77FE-409A-8FA3-8AC0176F1DBA@xxxxxx
Quote:
> Hi,
> only. I brought this laptop 1 year back and since 1 week I am facing this
> problem.
> me ?
> Thanks
> Rajesh A
Old 01-25-2009   #3 (permalink)
Ken Blake, MVP
On Sun, 25 Jan 2009 14:14:17 +0530, "Rajesh A"
<rajeshaz09@xxxxxx> wrote:
Quote:
> Hi,
Check with your laptop's manufacturer. It is very likely that the
reason for the problem is the number of times you've charged it, and
you may need a new battery.
Ken Blake, Microsoft MVP - Windows Desktop Experience
Please Reply to the Newsgroup
Old 01-25-2009   #4 (permalink)
Ian D
Quote:
> Hi,
> problem.
> me ?
> Thanks
> Rajesh A
Unless it's defective, the battery shouldn't lose capacity
in just one year. It may need a calibration. To do a
calibration, turn off all battery alarms and automatic
shut down settings in Power Options. Then let the
laptop run on battery until it fully discharges. After
that, charge the battery with the laptop off until it's
fully charged. Then you can turn on the laptop and
restore your battery power settings. I have an HP
laptop and HP recommends this procedure to restore
battery calibration.
Old 01-26-2009   #5 (permalink)
Richard G. Harper
Several people (myself included) have already replied to your earlier
message.
Quote:
> Hi,
> problem.
> me ?
> Thanks
> Rajesh A
Help needed - laptop battery will not charge General Discussion
My Battery doesnt charge Vista performance & maintenance
Battery percentage isn't changing Vista General
Vista RC1 will not charge battery Vista hardware & devices
how to charge a battery Vista hardware & devices
