Start Menu subfolders not visible for restricted users
  1. #1
    kakii Guest
    All that about vista 32bits business installation.
    All users have to be permitted to access some folder in the start menu.
    Physically this folder placed in c:\ProgramData\Microsoft\Windows\Start
    Menu......
    Read access privileges granted to all users, for elements in this
    directory and that folder:
    that folder-> properties-> security tab
    However following attempt fails always:
    that folder-> properties-> security tab -> advanced button -> edit
    button (the option "current inheritable privileges of child objects with
    inheritable privileges of this object to be replaced " is not checked)
    -> checking this option -> apply button -> option gets unchecked again.
    Why must it be so ?
    What is missing for this folder to be visible for all users ?
  2. #2
    kakii Guest
    Re: Start Menu subfolders not visible for restricted users
    Rick Rogers wrote:
    > Wrong place, use:
    > C:\Users\Default\AppData\Roaming\Microsoft\Windows\Start Menu
    Thanks for help.
    I will try this.
    By the way, Vista introduces significant innovations regarding
    system folders, their names, placement and number.
    What is the best document/manual for read to get familiarized
    with Vista system folders ?
  3. #3
    kakii Guest
    Rick Rogers wrote:
    > Hi,
    > I don't know of any one particular resource that covers it well. My
    > method of learning is the "tear it apart and then try to figure out how
    > to put it back together" method, and that doesn't work too well for most.
    No help, still the same. Have also tried to place it in the profile
    of that user who needs this access. No success.
    The issue that applying access privileges for all sub-objects fails
    after pushing the apply button repeats in this situation.
    If
    was better for this purpose why isn't Vista placing here all
    application invokers ?
    What's the difference between
    C:\Users\****\AppData\Roaming\Microsoft\Windows\Start Menu
    and
    c:\ProgramData\Microsoft\Windows\Start Menu......
    from Microsoft's point of view ?
    What is the former, and what is the latter best for ?
Start Menu subfolders not visible for restricted users problems?
Start Menu for All Users scott Vista General 3 26 Feb 2010
Long Delay When Displaying Icons in Start Menu Subfolders Neophile General Discussion 11 25 Apr 2009
Solved All Users Start Menu jake7363 General Discussion 3 30 Jul 2008
Access All Users & Default Users Start menu Henry Craven {SBS-MVP} Vista file management 3 21 Jul 2007
C:\Users\all users\start menu - DENIED James Vista file management 2 19 Oct 2006
