views problems
  1. #1
    KRK Guest
    views problems
    Hello
    Why do the views of the files in my folders keep changing ?
    Why do the subfolders not have the same view?
    It seems that I have to keep resetting the views, but next time I open a
    folder it has gone back to what it was before
    Help pls
    K
  2. #2
    Grand_Poobah Guest
    Re: views problems
    > Hello
    > a folder it has gone back to what it was before
    > Help pls
    > K
    Boy! You got that right. It seems no matter which way I want my folder
    contents viewed - and set that way - the next time I go there I get
    whatever Vista wants me to have. I have checked the "Remember folder
    views" so many times the checkbox is worn out. This does not help.
    Even going to the folder options and setting "make all folders look this
    way" doesn't help.
    GP
  3. #3
    Dave Guest
    Re: views problems
    Have you looked at...
    Windows Explorer Folder View settings
    Windows 7 beta
    http://get.live.com/wlmail/overview
    http://download.live.com/wlmail
    "Grand_Poobah" <whatever@xxxxxx> wrote in message
    news:espqq5thJHA.3812@xxxxxx
    >> Hello
    >> Help pls
    >> K
    > way" doesn't help.
    > GP
  4. #4
    Q Guest
    Re: views problems
    "KRK" wrote in message
    > Hello
    > Help pls
    > K
    Check this
    'Annoyances.org - Default Folder Template Patch'
    (http://www.annoyances.org/exec/show/choosetemplate)
    Q
  5. #5
    Grand_Poobah Guest
    Re: views problems
    Very interesting reading Dave. I may go that route if the PC Annoyances
    advice doesn't work. I don't mind messing with the Registry, but I will
    if I have to.
    GP
  6. #6
    Grand_Poobah Guest
    Re: views problems
    >> Hello
    >> open a folder it has gone back to what it was before
    >> Help pls
    >> K
    > Check this
    > Q
    Seems a bit easier than Dave's route. Both of them appear to be
    modifying that same areas of the Registry, but this one might just do
    the trick.
    GP
  7. #7
    zachd [MSFT] Guest
    Re: views problems
    It's a bug that's fixed in Windows Vista Service Pack 2 and Windows 7. You
    can use the registry resets to work around it in the interim. Sorry: it was
    a complex bug to reproduce and isolate.
    Speaking for myself only.
    See http://zachd.com/pss/pss.html for some helpful WMP info.
    "KRK" <trebor@xxxxxx> wrote in message
    news:%23weh%23NthJHA.4912@xxxxxx
    > Hello
    > Help pls
    > K
  8. #8
    Will Guest
    Re: views problems
    I certainly don't mind going to a website to read about how to fix an
    annoying problem in Vista, Lord knows, it's how I spend a good hour of my day
    ever since I installed Vista.
    But that posting about the folder views, seriously, it is THIRTY FIVE pages
    long. And ya know, the most recent stuff is posted last, so anyone can
    reasonably expect an end-user to read even FIVE pages, much less all 35, is
    beyond me.
    I do sincerely hope this nasty problem is fixed in SP2.
    Thanks,
    > > Hello
    > > Help pls
    > > K
  9. #9
    Cody Jarrett Guest
    Re: views problems
    On Sun, 12 Apr 2009 10:19:03 -0700, Will
    As Chicago Cubs fans know: "Hope springs eternal... "
views problems problems?
Folder List Pane/Quick Views Problems Crazy Nukeguy Live Mail 9 29 Mar 2009
Views Mario Martinez Live Mail 0 27 May 2008
I want "Details" in all views, dammit, *ALL* views... dont Vista General 4 07 Nov 2007
Problems with Thumbnail Views Franz Vista General 1 02 Nov 2007
UAC Views PowerUser Vista General 53 02 Oct 2006
