| Guest | Problems with Vista SP1 Ok, so I got a new laptop a few months ago which had Vista on it. I really liked it at first and had no problems with it, but for about a week now some problems have been developing. Firstly, it doesn't log on properly now, instead just going to a black screen with the white mouse pointer on it, and this seems to be getting worse by the day. At first it only took me about 3 attempts at logging on for it to work, but today it's taken me 11! As well as this it doesn't shut down properly; it gets stuck on the "logging off" screen and I have to turn it off manually using the power button on the laptop. Also, now I can't access the task manager. I click on the button to get onto it and the little green icon appears in the bottom right corner of the screen, but nothing else happens. There are some other smaller things that have happened such as it showing that I'm not connected to the internet when I am, and programs that previously worked fine now just crash. These problems all started happening on the same day and I've done nothing to set it off. Someone please help! |
| Problems with new Logitech S-150 speakers problems with x64 vista | Sound & Audio | |||
| Big vista problems need help icon/background/graphics/personalise problems | Vista performance & maintenance | |||
| Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 | Vista General | |||
| 2 different vista problems. Memory dump crash and startup repair cannot fix problems | Vista General | |||
| Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems | Vista installation & setup | |||
