Did not fix Modem Problem.
  1. #1
    Clark Guest
    Well, it looks like RC2 did not fix the modem driver problem that seemed to
    show up in 5728 (worked fine in 5600). If I allow the driver to be
    installed by Vista, and it wants to, the next boot will blue screen. If it
    makes a difference, I have a Zoom PCI Voice FaxModem.
    Clark
  2. #2
    Rick \Nutcase\ Rogers Guest
    Re: Did not fix Modem Problem.
    Bug it.
    You might also, for S&G's, try an XP driver. The BSOD is likely due to a
    driver issue, so sometimes taking advantage of the backwards compatibility
    resolves that.
    Best of Luck,
    Rick Rogers, aka "Nutcase" - Microsoft MVP
    http://mvp.support.microsoft.com/
    Windows help - www.rickrogers.org
    "Clark" <who@whoknows.com> wrote in message
    news:E06C8A77-261C-4827-A54C-1793FCD4FA2E@microsoft.com...
    > to show up in 5728 (worked fine in 5600). If I allow the driver to be
    > it makes a difference, I have a Zoom PCI Voice FaxModem.
    > Clark
  3. #3
    Clark Guest
    I tried the XP driver before and it did exactly the same thing. Since I
    can't change the Modem.sys file, I am going to see if there are any settings
    I can change. It does seem strange that when the drivers are installed, the
    modem will work. But on reboot, it blue screens and the modem must be
    uninstalled to recover. It seems a little backward to me that they have
    broken something that wasn't broken before.
    I have bugged it, so either they didn't have time, or didn't bother to fix
    it in this build, assuming the bug report was received. Doesn't someone in
    the Beta Testing Program know what bugs are being addressed?
    Thanks,
    Clark
    "Rick "Nutcase" Rogers" <rick@mvps.org> wrote in message
    news:uZEBpYg6GHA.4996@TK2MSFTNGP04.phx.gbl...
    > Bug it.
    > resolves that.
    > Best of Luck,
    >> Clark
  4. #4
    Hi Clark,
    Something about initializing the device is likely the problem, but whether
    it's an .ini file or the .sys file is difficult to tell.
    There's no public list of what's being or has been fixed and what isn't. Nor
    is there one for technical beta testers.
    Best of Luck,
    news:22D36332-F09C-4E6F-A327-335A6500CD75@microsoft.com...
    >settings I can change. It does seem strange that when the drivers are
    >installed, the modem will work. But on reboot, it blue screens and the
    >modem must be uninstalled to recover. It seems a little backward to me
    >that they have broken something that wasn't broken before.
    > in the Beta Testing Program know what bugs are being addressed?
    > Thanks,
    > Clark
    >> Bug it.
    >> compatibility resolves that.
    >> Best of Luck,
    >>> Clark
  5. #5
    Maurice Heath Guest
    I had the same problem here with the same modem a driver here Clark. Are
    you installing as a dual boot with vista on a partition that is NOT C:? My
    problems disappeared when I installed Vista as a dula boot to C: drive, I
    had previously experienced the exact same problems as you when I installed
    to V: drive. I think it may be badly coded drivers for the Zoom PCI modem
    which are hard referenced to C: so if you installed to any other drive
    letter you get the BSOD on reboot.
    Maurice
    news:uwzO%23Ch6GHA.2248@TK2MSFTNGP04.phx.gbl...
    > Hi Clark,
    > Nor is there one for technical beta testers.
    > Best of Luck,
    >> fix it in this build, assuming the bug report was received. Doesn't
    >> someone in the Beta Testing Program know what bugs are being addressed?
    >> Thanks,
    >> Clark
    >>> Bug it.
    >>> Best of Luck,
    >>>> seemed to show up in 5728 (worked fine in 5600). If I allow the driver
    >>>> to be installed by Vista, and it wants to, the next boot will blue
    >>>> screen. If it makes a difference, I have a Zoom PCI Voice FaxModem.
    >>>> Clark
  6. #6
    Clark Guest
    No, I installed on C:--no nonstandard installations, no dual boots. The
    driver works fine until a reboot. I was wondering if I could change the IRQ
    or comm port, but it appears that is not allowed.
    Clark
    "Maurice Heath" <mauriceheath@hotmail.com> wrote in message
    news:%23Wxcwwl6GHA.4552@TK2MSFTNGP05.phx.gbl...
    > Maurice
    >> Hi Clark,
    >> whether it's an .ini file or the .sys file is difficult to tell.
    >> Best of Luck,
    >>> Thanks,
    >>> Clark
    >>>> Bug it.
    >>>> a driver issue, so sometimes taking advantage of the backwards
    >>>> Best of Luck,
    >>>>> driver to be installed by Vista, and it wants to, the next boot will
    >>>>> blue screen. If it makes a difference, I have a Zoom PCI Voice
    >>>>> FaxModem.
    >>>>> Clark
  7. #7
    Clark Guest
    I was also thinking about the unimodem driver for the speaker. If I disable
    just that part, I don't get a blue screen, but I do get a boot into a black
    hole!!!
    I might try disabling the Soundblaster driver next to see if that effects
    it.
    It is too bad they didn't just leave it alone because it worked in 5600.
    Clark
    news:OX5UnWm6GHA.3620@TK2MSFTNGP04.phx.gbl...
    > IRQ or comm port, but it appears that is not allowed.
    > Clark
    >> Maurice
    >>> Hi Clark,
    >>> Best of Luck,
    >>>> Thanks,
    >>>> Clark
    >>>>> Bug it.
    >>>>> Best of Luck,
    >>>>>> FaxModem.
    >>>>>> Clark
  8. #8
    Maurice Heath Guest
    Can't say I've experienced any black holes, but I have to agree with you on
    leaving it alone. 5600 is the most stable and functional release for my
    setup, I can't believe that 5728 & 5744 are later versions and yet present
    more problems. It does not bode well seeing as RTM is so close.
    Maurice
    news:30B78A3A-8223-4105-8916-72E88223CE27@microsoft.com...
    >disable just that part, I don't get a blue screen, but I do get a boot into
    >a black hole!!!
    > it.
    > Clark
    >> Clark
    >>>My problems disappeared when I installed Vista as a dula boot to C:
    >>>drive, I had previously experienced the exact same problems as you when I
    >>>installed to V: drive. I think it may be badly coded drivers for the
    >>>Zoom PCI modem which are hard referenced to C: so if you installed to any
    >>>other drive letter you get the BSOD on reboot.
    >>> Maurice
    >>>> Hi Clark,
    >>>> isn't. Nor is there one for technical beta testers.
    >>>> Best of Luck,
    >>>>>I can't change the Modem.sys file, I am going to see if there are any
    >>>>> addressed?
    >>>>> Thanks,
    >>>>> Clark
    >>>>>> Bug it.
    >>>>>> to a driver issue, so sometimes taking advantage of the backwards
    >>>>>> Best of Luck,
    >>>>>>> FaxModem.
    >>>>>>> Clark
Did not fix Modem Problem. problems?
Modem problem Grandad Vista General 2 12 Feb 2009
Modem Access Problem Georsad Vista networking & sharing 1 17 Oct 2007
Modem problem Frank Fox Vista General 0 02 Jul 2007
DSL & Modem Dialup Problem......... CSM Vista General 0 20 May 2007
modem problem thumper380 Vista hardware & devices 1 05 Feb 2007
