Vista - System Restore Question
Old 02-12-2009   #1 (permalink)
Pat
How can I delete all but the last 2 or 3 System Restore points? I know I
cann turn them all off but I want to save the last ones done earlier in the
month.
Pat
Old 02-12-2009   #2 (permalink)
Eric
Re: System Restore Question
On Feb 12, 1:08*pm, "Pat" <pat...@xxxxxx> wrote:
Quote:
> How can I delete all but the last 2 or 3 System Restore points? *I knowI
> month.
> Pat
Delete a restore point -
http://windowshelp.microsoft.com/Win...384fb1033.mspx
Eric,
PC Buyer Beware!
http://www.pcbuyerbeware.co.uk/
Old 02-12-2009   #3 (permalink)
VISTA HOME PREMIUM X64/ 7 x64 / 7x86
Hello Pat,
You might try reducing the amount of space allocated for System Restore.
System Restore - disk space
3gb is suggested in the tutorial and you could try reducing it gradually till you get to an amount you are happy with.
From then on , there will only be that amount of space allocated before the older points are removed.
Hope it helps
SIW2
Quote  Quote: Originally Posted by Pat View Post
month.
Pat
Old 02-12-2009   #4 (permalink)
Ken Blake, MVP
> month.
You can *not* do that. You have only three choices:
1. Delete all of them.
2. Delete all but the most recent one.
3. Delete none of them.
Ken Blake, Microsoft MVP - Windows Desktop Experience
Please Reply to the Newsgroup
Old 02-12-2009   #5 (permalink)
Saucy
"Pat" <patetc@xxxxxx> wrote in message
news:6E8BA4AE-5D79-4659-A18F-4AC485F34C24@xxxxxx
> the month.
> Pat
Pat:
You can delete all but the last Restore Point using "Disk Cleanup"
Start > All Programs > Accessories > System Tools > Disk Cleanup
If asked, select "Files from all users on this computer".
The select drive dropbox will start, so select C: .
Once that's done the dialogue box will show and there will be a "More
Options" tab at the top. Click it, then click the "Clean Up.." button in the
"System Restore and Shadow Copies" section. Click any necessary OKs. The
program will clean up the disk and will remove excess Restore Points.
Saucy
System Restore Question Vista General
Another system restore question Vista General
