| | RC 1 small problems with disk cleaner and shortcut hotkeys Anyone else having problem with Disk Cleaner not working on RC1. When I start it, it begins to work and then it stops and Windows informs me there is a problem searches for a solution, and doesn't find it. I am also unable to get Vista to remember my hotkeys for running my programs. I can go in and redefine them under shortcut properties and they will work until I reboot Windows and then they don't work again. (Comment: I have never tested a version of Windows that didn't have trouble with this: Win95, 98, 2000, or XP). |
| | Re: RC 1 small problems with disk cleaner and shortcut hotkeys DEP (Data Execution Prevention) shuts down cleanmgr.exe if I attempt to run it on drive C. It runs fine on my USB harddrive. I thought it might be problems with the disk so ran scandisk and it did find minor errors and fixed them, but it made no difference. The box about DEP comes up and says I can deactivate it for programs that are not compatible; however, this Windows app should be compatible. Anyone have any ideas. Is this a bug? I find that ccleaner.exe 1.33, which I was using on XP was not disabled so it apparently runs, but it doesn't seem to be as effective as before. Have cookies and stuff moved on Vista? "SteveC" <sconklan.nospam@yahoo.com> wrote in message news:EDC6CB18-9BB0-40C9-8A64-A4E368E47103@microsoft.com... > Anyone else having problem with Disk Cleaner not working on RC1. When I > start it, it begins to work and then it stops and Windows informs me there > is a problem searches for a solution, and doesn't find it. > > I am also unable to get Vista to remember my hotkeys for running my > programs. I can go in and redefine them under shortcut properties and > they will work until I reboot Windows and then they don't work again. > (Comment: I have never tested a version of Windows that didn't have > trouble with this: Win95, 98, 2000, or XP). |
| Wise Disk Cleaner Pro - FREE today only | Software | |||
| Reinstalled Vista, now I want to use bitlocker again..what to do about the small partition that is on the disk already? | Vista security | |||
| Insert Microsoft Office XP Small Business disk | Vista General | |||
| Vista disk cleaner crash system | Vista General | |||
| Disk Cleanup - How to delete Hibernation File Cleaner 893MB | Vista performance & maintenance | |||
