| Guest | Re: Keyboard shortcuts for Shortcuts does not work on next logon /George Valkov/ said: > Keyboard shortcuts for Shortcuts in the start menu does not work on next > logon. In what version. They had the behavior that you describe in RC1. Fixed in later builds, including RC2. |
| Guest | Keyboard shortcuts for Shortcuts does not work on next logon Keyboard shortcuts for Shortcuts in the start menu does not work on next logon. |
| Guest | Re: Keyboard shortcuts for Shortcuts does not work on next logon I just burned the ISO and installed Vista RC1 two days ago. Luckily I have to reformat and install again, this time RC2. Thank You! <dev@null.invalid> wrote in message news:O%23BGOam6GHA.4232@TK2MSFTNGP02.phx.gbl... > /George Valkov/ said: >> Keyboard shortcuts for Shortcuts in the start menu does not work on next >> logon. > > In what version. They had the behavior that you describe in RC1. Fixed > in later builds, including RC2. |
| Keyboard Shortcuts | Vista General | |||
| Keyboard shortcuts | Vista General | |||
| Keyboard Shortcuts don't work | Vista General | |||
| Keyboard shortcuts for program's shortcuts do not work | Vista General | |||
