| | A heat problem or CPU My PC started to crash 15 min after start up then it shuts down and restarts and restarts over and over and never really restarts until I shut the pc off and let it sit for 20 or 30 minutes then it starts ok but pretty soon it starts to shut down all over again. Do you think it is heat or is my CPU going to die? |
| | Re: A heat problem or CPU "Merle" <planogram@xxxxxx> wrote in message news:9309103E-049A-4D2D-96DE-B070E000B511@xxxxxx Quote: > My PC started to crash 15 min after start up then it shuts down and > restarts and restarts over and over and never really restarts until I shut > the pc off and let it sit for 20 or 30 minutes then it starts ok but > pretty soon it starts to shut down all over again. Do you think it is > heat or is my CPU going to die? I think that maybe you should get a can of compressed air and remove the buildup of dust that is probably between the fins of the CPU heatsink.. You might also want to blow out the power supply, video card fan etc.. -- Mike Hall - MVP Mike's Window - My Blog.. http://msmvps.com/blogs/mikehall/default.aspx |
| | Re: A heat problem or CPU Merle wrote: Quote: > My PC started to crash 15 min after start up then it shuts down and > restarts and restarts over and over and never really restarts until I shut > the pc off and let it sit for 20 or 30 minutes then it starts ok but > pretty soon it > starts to shut down all over again. Do you think it is heat or is my CPU > going to die? reading about it to tell. One would need to have hands-on the computer to test. Assuming this is a desktop computer, open it up and blow out all the dust bunnies using compressed air. Unless you live somewhere it's still snowy, taking the computer outside to do this is A Good Thing. Then run the computer open, observing all the fans. Don't neglect to check the fan on top of the processor and the one on the video card (if present). If the computer runs perfectly, then you know it was overheating and can take steps to fix this. Since I have no idea what your computing environment is, the state of the computer, etc. I can't give you exact steps. Clean computers preferably placed not on the floor in a smoke-free, pet-hair free environment are a goal. If your computer still shuts down after doing the above, then you have other hardware problems. Could be the power supply, could be the processor, could be the motherboard. You know your own skill level best for troubleshooting. http://www.elephantboycomputers.com/...ardware_Tshoot Testing hardware failures often involves swapping out suspected parts with known-good parts. If you can't do the testing yourself and/or are uncomfortable opening your computer, take the machine to a professional computer repair shop (not your local equivalent of BigComputerStore/GeekSquad). If possible, have all your data backed up before you take the machine into a shop. Malke -- MS-MVP Elephant Boy Computers - Don't Panic! http://www.elephantboycomputers.com/#FAQ |
| | Re: A heat problem or CPU "Mike Hall - MVP" <mikehall@xxxxxx_mvps.com> wrote in message news:erqmPgFlJHA.4760@xxxxxx Quote: > "Merle" <planogram@xxxxxx> wrote in message > news:9309103E-049A-4D2D-96DE-B070E000B511@xxxxxx Quote: >> My PC started to crash 15 min after start up then it shuts down and >> restarts and restarts over and over and never really restarts until I >> shut the pc off and let it sit for 20 or 30 minutes then it starts ok but >> pretty soon it starts to shut down all over again. Do you think it is >> heat or is my CPU going to die? > > I think that maybe you should get a can of compressed air and remove the > buildup of dust that is probably between the fins of the CPU heatsink.. > You might also want to blow out the power supply, video card fan etc.. > > > -- > Mike Hall - MVP > > Mike's Window - My Blog.. > http://msmvps.com/blogs/mikehall/default.aspx > > > > I'll let it percolate for about an hour and see if it shuts down anymore. |
| Heat issues with amd!! | Vista performance & maintenance | |||
| Can a PSU cause heat problems? | Overclocking & Cooling | |||
| Heat | Vista hardware & devices | |||
| Testing System Heat (GPU & HD) | Vista hardware & devices | |||
