| | MLM on Vista Problem (sorry if this is the wrong place to put it) 4 days ago I got signed out of WLM and when I tried to sign back in I got the message "We can't sign you into WLM ... service is unavailable 8100030d." Since then everytime I've tried to log in I get the same message. I did some searching and found a few things but nothing worked. I tried turning it off and on again I uninstalled and re-downloaded messenger I have the newest version of messenger I created a new account but still couldn't log in with that. My Date/Time is set to the correct time I disabled time zone alarm WLM is allowed though my firewall I can log into my hotmail online and sign into webmessenger I read something which said to register some dll's but when I did I got another error. "The module MSXML3.dll was located but the call to DLLRegisterSever failed with error code 0x80070005." "The module wintrust.dll was located but the call to DLLRegisterSever failed with error code 0x80070005." "The module initpki.dll failed to load ... The specified module could not me found." Any ideas of what I have to do to make it let me log in again? (i'm using Vista home premium on a laptop btw) -- CJR100 ------------------------------------------------------------------------ CJR100's Profile: http://forums.techarena.in/members/cjr100.htm View this thread: http://forums.techarena.in/vista-help/1130922.htm http://forums.techarena.in |
| vista ultimate 32bit,64bit,Seven Ultimate 64bit | Re: MLM on Vista Problem (sorry if this is the wrong place to put it) are you using a router and a high speed modem? power down your ENTIRE SYSTEM, then unplug EVERYTHING and wait 30 seconds. then plug in the router. wait 30 seconds. then repeat for the modem. then finally, the computer. and make sure your proxy settings are correct if you use one. and turn off zonealarm if you use that |
| | Re: MLM on Vista Problem (sorry if this is the wrong place to put it) Thanks for the advise. I tried it but still got the same error message. Any other ideas? There must be some way to correct it. Maybe something to do with the dll's that didn't work. -- CJR100 ------------------------------------------------------------------------ CJR100's Profile: http://forums.techarena.in/members/cjr100.htm View this thread: http://forums.techarena.in/vista-help/1130922.htm http://forums.techarena.in |
| windows mail looks in wrong place when trying to open attachments | Vista mail | |||
| CD/DVD drive shows wrong icon when I place a disc in the drive | Vista General | |||
| Mouse pointer clicks in wrong place | Vista General | |||
| Putting a certificate in the proper place after accidentally puttingit in the wrong place | Vista security | |||
| cannot install because it's looking in the wrong place | Vista installation & setup | |||
