| | System Stability Chart trends Once in a while when an applications fails to terminate and I kill it that action will be reflected in the Reliability and Performance Monitor. I expect it, and see it in a dip on the graph. What puzzles me is what makes the graph go back up? My reliability index has been stuck at 8.45 for the last two weeks. I have had NO failure entries and just a few "Info" entries that appear when updates install properly. The graph has flat-lined at 8.45. All the MS/Vista bashers can forego the terribly funny retorts please. Questor |
| Reliability Monitor System Stability | Vista performance & maintenance | |||
| Preformance Monitor is this ok?Sys Stability Chart | Vista General | |||
| System stability chart | Vista General | |||
| OS Trends | Vista General | |||
| [demo] Format-Chart - Formats output as a table with a chart colum | PowerShell | |||
