Vista - How to reset to default cleartype settings???
Old 03-09-2009   #1 (permalink)
Ole
I'm new to Vista and all ready messed it up :-(
The cleartype factory setting was actually very good, but as the geek I
am I thought that I could improve it by using the Microsoft online
cleartype tuner.... I was wrong - I've tried all the possible 16
settings but none of them worked very weel and now I can't find a way to
reset my cleartype to factory setting - please help!
Thanks
Ole
Old 03-09-2009   #2 (permalink)
Re: How to reset to default cleartype settings???
Hello Ole,
You should still be able to adjust them back using the normal method in Vista. This tutorial will help show you how to if needed.
ClearType Font Settings
Quote  Quote: Originally Posted by Ole View Post
Thanks
Ole
Old 03-09-2009   #3 (permalink)
Ole
Brink skrev:
Quote:
> Hello Ole,
> Hope this helps,
> Shawn
>> to
>> Thanks
>> Ole
Found the setting from a fresh installed Vista PC - the factory setting
of the "fontsmoothinggamma" parameter is 0
BR
Ole
Old 03-09-2009   #4 (permalink)
Very nice Ole. I'm happy to hear that you got it sorted. Thank you for sharing your results.
Brink skrev:
Quote:
> Hello Ole,
> Hope this helps,
> Shawn
>> to
>> Thanks
>> Ole
BR
Ole
Reset IE7 Settings VB Script
Mouse settings reset to default every time Vista hardware & devices
factory reset/default settings Vista performance & maintenance
Folder settings in Vista keep going back to the default settings Vista General
ClearType Font Settings Tutorials
