Vista - Downloading Problems with vista
Old 03-10-2009   #1 (permalink)
hoth2o
this morning i logged on and when I tried to download pictures from my
email I received the message below. I then went to a few other sites to
try to download and I kept getting the same message. I ran a system
restore. It didn't help. I am a newbie with vista and the whole
computer world. Thanks for any and all help.
Message I get when trying to download anything....
C:\Users\COMPAQ~1\AppData\Local\Temp\IeyYtbA3.exe.part could not be
saved, because the source file could not be read.
Try again later, or contact the server administrator.
hoth2o
Old 03-10-2009   #2 (permalink)
Windows XP Proffesional x64, Windows Vista Ultimate x64, Windows 2008 Server x64
Re: Downloading Problems with vista
from the description you provided, today is probably your lucky day
Pictures (binary digital images) usually have these extensions: .jpg, .png, .bmp, .tga, .tif, .tiff
Pictures (vectorized images) usually have these extensions: .svg, .cmx, .emf, .wmf, .cdr, .cmx, .ai, .ps, .eps
Executables usually have these extensions (after installation of the Windows operating system, I took these from PATHEXT environment variable, visible when you type set and press enter key from Command Prompt): .COM, .EXE, .BAT, .CMD, .VBS, .VBE, .JS, .JSE, .WSF, .WSH, .MSC
The extension you are mentioning is .exe, which means that it is an binary file that can be executed on your computer. Usually, when you get similar message that the file "could not be saved, because the source file could not be read" it means that access to it was blocked by some kind of malware-protection you have installed on your machine, which is good.
However, if you are completely sure (but how you can be? think about identity theft issues) that the executable image is not lethal, there is very tiny chance that this could be false-positive detection.
HTH,
VLaaD
Old 03-10-2009   #3 (permalink)
hoth2o
VLaaD;801645 Wrote:
Quote:
> Hi,
> *.jpg*,
> *.png*, *.bmp*, *.tga*, *.tif*, *.tiff*
> Pictures (vectorized images) usually have these extensions: *.svg*,
> *.cmx*, *.emf*, *.wmf*, *.cdr*, *.cmx*, *.ai*, *.ps*, *.eps*
> Windows operating system, I took these from *PATHEXT* environment
> variable, visible when you type *set* and press *enter key* from
> *Command Prompt*): *.COM*, *.EXE*, *.BAT*, *.CMD*, *.VBS*, *.VBE*,
> *.JS*, *.JSE*, *.WSF*, *.WSH*, *.MSC*
> The extension you are mentioning is *.exe*, which means that it is an
> get
> similar message that the file "-could not be saved, because the source
> file could not be read-" it means that access to it was blocked by
> some
> is
> good.
> is
> HTH,
> VLaaD
> VLaaD
thank you for your answer but i'm not quite sure what you mean. I cant
download anything. I tried to download Firefox browser and i got that
message, I tried to download Chrome and got the same message, pictures
from email...same message....programs, software, itunes, etc...i get
the same message.
I dont know much about computers and i dont really download a whole lot
so i'm not sure how long this has been a problem.
I appreciate your help but is there a way to fix it?
hoth2o
Downloading/uploading vista problems Network & Sharing
downloading problems Vista General
Vista problems when downloading software? Vista General
Problems downloading film from Sony Video Camera on Vista Premium Vista hardware & devices
Downloading problems Vista networking & sharing
