Vista - help to copy the Dark Knight and Wall-e DVDs on Vista
Old 03-10-2009   #1 (permalink)
alexa09
I am trying to make two backup copies of the Dark Knight and Wall-E
DVDs, but they end with an error saying that the DVD might be
protected.
I am using Windows Vista 32 bit.
Any help would be appreciated!
alexa09
Posted via http://ms-os.com Forum to Usenet gateway
Old 03-11-2009   #2 (permalink)
Sonny Wortzik
Re: help to copy the Dark Knight and Wall-e DVDs on Vista
On Tue, 10 Mar 2009 22:52:33 -0500, alexa09
>protected.
They are copy-protected you moron.
Old 03-12-2009   #3 (permalink)
alexa09
Thanks for the suggestions. I will give a try.
alexa09
Jedi knight dark forces 2 on vista x64 Gaming
Dark Forces 2 - Jedi Knight Gaming
Just installed a Xigmatek Dark Knight LGA1366 :-) Overclocking & Cooling
Star Wars Jedi Knight Dark Forces 2 black screen Gaming
Star Wars - Dark Forces II: Jedi Knight Gaming
