Vista - Remote Desktop does not connect, no error, nothing
Old 03-11-2009   #1 (permalink)
Simon
I have been connecting to my work computer via remote desktop for quite
sometime now without any problems.
But now I cannot connect anymore.
The weird thing is that I get no error message, nothing.
The 'connect' button is disabled for a short while, then after about 5
seconds it is enabled again. No errors, no nothing. If I enter the wrong IP
address I get an error message.
I can ping work IP address.
So what could be the problem?
Why am I not connecting and why am I not getting any errors?
Thanks
Simon
Old 03-11-2009   #2 (permalink)
MBUnit
Re: Remote Desktop does not connect, no error, nothing
Simon wrote:
Quote:
> Hi,
> IP address I get an error message.
Have you checked with personnel at work about this? Sometimes, things
change on the other end to prevent a connection that worked before. Also
have you tried using another machine and the problem did not follow to
the other machine?
Old 03-11-2009   #3 (permalink)
Simon
> have you tried using another machine and the problem did not follow to the
> other machine?
Well, I can check at work tomorrow, it is possible that something has
changed.
But having said that, why would I not get any error messages?
When I try and connect to another machine, (one that I do not have
permission to), I do get an error message.
But in this case I get nothing, no error, no warning, nothing.
Simon
can't connect to remote desktop Vista General
Remote Desktop won't connect Network & Sharing
Remote Desktop does not connect. Vista General
Error message using remote desktop to connect to Server 2003 Vista General
Remote Desktop will not connect Vista General
