| | WebDAV (mini-redirector): double-click in an SSL-enabled WebDAV-folder to open an Office 2003 file does not work Operating system: Vista Office: 2003 WebDAV client: Microsoft Vista Mini-Redirector 6.00.0xx WebDAV server: Microsoft IIS 6.0, SSL-enabled Having an WebDAV folder open (URL: https://iisdav.testinfra.local/WebDAV/Test.doc ) and double-click on an Office-2003 file. --> Office starts, but claims, that it cannot open the file (note the changed / mixed-up URL): "http://SSL/WebDAV/Test.doc could not be opened" Clicking on OK leads to: " \\iisdav.testinfra.local@xxxxxx\WebDAV\Test.doc could not be opened. .. . ." Looking in the Server-side logfiles of IIS 6 shows, that Mini-Redirector is acting (and failing) despite Office 2003 bringing its own Rosebud client. - is this an known problem? - is there an hotfix or SP for this problem? - is there an workaround? - How can Rosebud be forced to be used instead of Mini-Redirector? Rudolf |
| Vista Business 32bit | Re: WebDAV (mini-redirector): double-click in an SSL-enabled WebDAV-folder to open an Operating system: Vista Office: 2003 WebDAV client: Microsoft Vista Mini-Redirector 6.00.0xx WebDAV server: Microsoft IIS 6.0, SSL-enabled Having an WebDAV folder open (URL: https://iisdav.testinfra.local/WebDAV/Test.doc ) and double-click on an Office-2003 file. --> Office starts, but claims, that it cannot open the file (note the changed / mixed-up URL): "http://SSL/WebDAV/Test.doc could not be opened" Clicking on OK leads to: " \\iisdav.testinfra.local@xxxxxx\WebDAV\Test.doc could not be opened. .. . ." Looking in the Server-side logfiles of IIS 6 shows, that Mini-Redirector is acting (and failing) despite Office 2003 bringing its own Rosebud client. - is this an known problem? - is there an hotfix or SP for this problem? - is there an workaround? - How can Rosebud be forced to be used instead of Mini-Redirector? Rudolf Since Vista, I'm no longer able to access a document via MS Word through Webdav over HTTPS. I get the same error. Is any further information known yet? (note that I'm not using IIS but Apache with a custom PHP Webdav implementation) Edit: on 2nd thought, the error I get is slightly different as it does not change the url. It just says: "Could not open 'https://servername/path/filename.rtf'.". Without SSL, it seems to work just fine. |
| Double-click to open attachment doesn't work | Vista mail | |||
| Adding SSL-enabled WebDAV with self-signed certificate as a networkdrive | Vista General | |||
| Documents from WebDAV folders open read only in Office 2007 andWindows Vista | Vista General | |||
| WebDAV-Redirector/WebClient-Service: Error Messages, Upload issues | Vista networking & sharing | |||
| Problem with Vista/Office 2007 and WebDAV | Vista General | |||
