| | Managed to fix power off and reboot problem I've managed to fix my power off and reboot problem. Others have said they're having the same problem. If you've got a Via Sata Raid controller, download the Via Raid 530c drivers from somewhere like http://drivers.softpedia.com/get/Oth...AID-530c.shtml Right click on the downloaded file and select `Extract all` Go into the extracted directory and right click on SETUP and run as administrator. Click on allow to whatever messages appear. Then the PC will want to reboot. This will hang as usual. Once you've re-set your PC and booted it, go into `Device Drivers` `Storage Controllers` `Via SATA Raid controller` and click on the driver tab. Click on `Update Driver` then `Browse my computer for Driver software` then `Let me pick a list of device drivers on my computer` then `have disk` Browse to `Wherever you extracted your 5.30 drivers to`\drvdisk\AMD64\2003x64 and select VIAMRX64 Click on Next etc to install this, your PC will then want to reboot. I cant remember whether it rebooted fine at this point or not. But once it's rebooted, it finds a new device, installs automatically and now my PC reboots and powers off fine. Note, if you don't follow the above instructions to manually pick the driver, it tells you (well it told me) that a suitable driver was already installed. Hope this helps Phil |
| | Re: Managed to fix power off and reboot problem Phil, Good find, thanks! Bill F. "Phil" <Phil@discussions.microsoft.com> wrote in message news:66F17526-A109-40D1-9D2D-2160D0309624@microsoft.com... > I've managed to fix my power off and reboot problem. > > Others have said they're having the same problem. > > If you've got a Via Sata Raid controller, download the Via Raid 530c > drivers > from somewhere like > > http://drivers.softpedia.com/get/Oth...AID-530c.shtml > > Right click on the downloaded file and select `Extract all` > > Go into the extracted directory and right click on SETUP and run as > administrator. > > Click on allow to whatever messages appear. Then the PC will want to > reboot. > This will hang as usual. > > Once you've re-set your PC and booted it, go into `Device Drivers` > `Storage > Controllers` `Via SATA Raid controller` and click on the driver tab. Click > on > `Update Driver` > > then `Browse my computer for Driver software` > > then `Let me pick a list of device drivers on my computer` > > then `have disk` > > Browse to `Wherever you extracted your 5.30 drivers > to`\drvdisk\AMD64\2003x64 > > and select VIAMRX64 > > Click on Next etc to install this, your PC will then want to reboot. I > cant > remember whether it rebooted fine at this point or not. But once it's > rebooted, it finds a new device, installs automatically and now my PC > reboots > and powers off fine. > > Note, if you don't follow the above instructions to manually pick the > driver, it tells you (well it told me) that a suitable driver was already > installed. > > Hope this helps > > Phil |
| | RE: Managed to fix power off and reboot problem I followed your procedure for x86 and it works to. Thanks a lot. ORjunior "Phil" wrote: > I've managed to fix my power off and reboot problem. > > Others have said they're having the same problem. > > If you've got a Via Sata Raid controller, download the Via Raid 530c drivers > from somewhere like > > http://drivers.softpedia.com/get/Oth...AID-530c.shtml > > Right click on the downloaded file and select `Extract all` > > Go into the extracted directory and right click on SETUP and run as > administrator. > > Click on allow to whatever messages appear. Then the PC will want to reboot. > This will hang as usual. > > Once you've re-set your PC and booted it, go into `Device Drivers` `Storage > Controllers` `Via SATA Raid controller` and click on the driver tab. Click on > `Update Driver` > > then `Browse my computer for Driver software` > > then `Let me pick a list of device drivers on my computer` > > then `have disk` > > Browse to `Wherever you extracted your 5.30 drivers to`\drvdisk\AMD64\2003x64 > > and select VIAMRX64 > > Click on Next etc to install this, your PC will then want to reboot. I cant > remember whether it rebooted fine at this point or not. But once it's > rebooted, it finds a new device, installs automatically and now my PC reboots > and powers off fine. > > Note, if you don't follow the above instructions to manually pick the > driver, it tells you (well it told me) that a suitable driver was already > installed. > > Hope this helps > > Phil |
| | RE: Managed to fix power off and reboot problem Phil, Thanks I manually installed the older Raid Controller inf. and now all is well again. "Phil" wrote: > I've managed to fix my power off and reboot problem. > > Others have said they're having the same problem. > > If you've got a Via Sata Raid controller, download the Via Raid 530c drivers > from somewhere like > > http://drivers.softpedia.com/get/Oth...AID-530c.shtml > > Right click on the downloaded file and select `Extract all` > > Go into the extracted directory and right click on SETUP and run as > administrator. > > Click on allow to whatever messages appear. Then the PC will want to reboot. > This will hang as usual. > > Once you've re-set your PC and booted it, go into `Device Drivers` `Storage > Controllers` `Via SATA Raid controller` and click on the driver tab. Click on > `Update Driver` > > then `Browse my computer for Driver software` > > then `Let me pick a list of device drivers on my computer` > > then `have disk` > > Browse to `Wherever you extracted your 5.30 drivers to`\drvdisk\AMD64\2003x64 > > and select VIAMRX64 > > Click on Next etc to install this, your PC will then want to reboot. I cant > remember whether it rebooted fine at this point or not. But once it's > rebooted, it finds a new device, installs automatically and now my PC reboots > and powers off fine. > > Note, if you don't follow the above instructions to manually pick the > driver, it tells you (well it told me) that a suitable driver was already > installed. > > Hope this helps > > Phil |
| | RE: Managed to fix power off and reboot problem How did you get it to work on X86. i cant install the driver. It says i need to use a driver built for the 32 bit system.. Dove "orjunior" wrote: > I followed your procedure for x86 and it works to. > > Thanks a lot. > > ORjunior > > "Phil" wrote: > > > I've managed to fix my power off and reboot problem. > > > > Others have said they're having the same problem. > > > > If you've got a Via Sata Raid controller, download the Via Raid 530c drivers > > from somewhere like > > > > http://drivers.softpedia.com/get/Oth...AID-530c.shtml > > > > Right click on the downloaded file and select `Extract all` > > > > Go into the extracted directory and right click on SETUP and run as > > administrator. > > > > Click on allow to whatever messages appear. Then the PC will want to reboot. > > This will hang as usual. > > > > Once you've re-set your PC and booted it, go into `Device Drivers` `Storage > > Controllers` `Via SATA Raid controller` and click on the driver tab. Click on > > `Update Driver` > > > > then `Browse my computer for Driver software` > > > > then `Let me pick a list of device drivers on my computer` > > > > then `have disk` > > > > Browse to `Wherever you extracted your 5.30 drivers to`\drvdisk\AMD64\2003x64 > > > > and select VIAMRX64 > > > > Click on Next etc to install this, your PC will then want to reboot. I cant > > remember whether it rebooted fine at this point or not. But once it's > > rebooted, it finds a new device, installs automatically and now my PC reboots > > and powers off fine. > > > > Note, if you don't follow the above instructions to manually pick the > > driver, it tells you (well it told me) that a suitable driver was already > > installed. > > > > Hope this helps > > > > Phil |
| | #6 (permalink) |
| | RE: Managed to fix power off and reboot problem Same as Dove. It says that I cannot install on a 32-bit system. "AKWolf" wrote: > Phil, Thanks I manually installed the older Raid Controller inf. and now all > is well again. > > "Phil" wrote: > > > I've managed to fix my power off and reboot problem. > > > > Others have said they're having the same problem. > > > > If you've got a Via Sata Raid controller, download the Via Raid 530c drivers > > from somewhere like > > > > http://drivers.softpedia.com/get/Oth...AID-530c.shtml > > > > Right click on the downloaded file and select `Extract all` > > > > Go into the extracted directory and right click on SETUP and run as > > administrator. > > > > Click on allow to whatever messages appear. Then the PC will want to reboot. > > This will hang as usual. > > > > Once you've re-set your PC and booted it, go into `Device Drivers` `Storage > > Controllers` `Via SATA Raid controller` and click on the driver tab. Click on > > `Update Driver` > > > > then `Browse my computer for Driver software` > > > > then `Let me pick a list of device drivers on my computer` > > > > then `have disk` > > > > Browse to `Wherever you extracted your 5.30 drivers to`\drvdisk\AMD64\2003x64 > > > > and select VIAMRX64 > > > > Click on Next etc to install this, your PC will then want to reboot. I cant > > remember whether it rebooted fine at this point or not. But once it's > > rebooted, it finds a new device, installs automatically and now my PC reboots > > and powers off fine. > > > > Note, if you don't follow the above instructions to manually pick the > > driver, it tells you (well it told me) that a suitable driver was already > > installed. > > > > Hope this helps > > > > Phil |
| | #7 (permalink) |
| | RE: Managed to fix power off and reboot problem you need to select /drvdisk/i386/NT5 for the 32bit version of vista. "ton62" wrote: > Same as Dove. It says that I cannot install on a 32-bit system. > |
| | #8 (permalink) |
| | Re: Managed to fix power off and reboot problem "Dove" <Dove@discussions.microsoft.com> wrote in message news:27912544-1977-4E19-BED4-6D53A8BFB3A8@microsoft.com... > How did you get it to work on X86. i cant install the driver. It says i > need > to use a driver built for the 32 bit system.. > > Dove > > X86 is the 32-bit edition of Vista. It is an arcane numbering system that harkens back to the halcyon days of Motorola CPU model numbers. So, Dove, if you are getting a message that says you need to use a driver built for a 32-bit system, perhaps you have inadvertently tried to install a driver that was built for a 64-bit system. |
| | #9 (permalink) |
| | RE: Managed to fix power off and reboot problem Installing VIA VT8237 Driver 5.30c fixed the problem. Thanks Phil. Make sure that Microsoft hear this, as this is a new issue, previous releases worked fine. Also I noticed that with this driver my PC is loading much faster than before, but the Rating for the HD still the same: 5,2 (I ran the assesment tool again of course...) |
| | #10 (permalink) |
| | RE: Managed to fix power off and reboot problem It worked.. Thx... ![]() Dove "Shawn" wrote: > you need to select /drvdisk/i386/NT5 for the 32bit version of vista. > > "ton62" wrote: > > > Same as Dove. It says that I cannot install on a 32-bit system. > > > |
| Power Outtage & reboot problems | Drivers | |||
| Intellisense and C# / managed C++ DLL problem. | .NET General | |||
| Problem registering managed component with COM | .NET General | |||
| Reboot problem | Vista General | |||
| Vista {Insert power option here} causes Reboot | Vista General | |||
