Vista - Problem install RC2
Old 10-08-2006   #1 (permalink)
Piet Fourie
Problem install RC2
Have downloaded RC2 and burned the DVD. Can I update my current RC1 with it,
as it does not want to work. It complains Autorun.dll could not be run or a
problem with SPWIZENG.DLL ??
Do anybody have a suggestion
Piet
Old 10-08-2006   #2 (permalink)
Judy
Re: Problem install RC2
did you reboot from the DVD? You need to or not use the autorun. if you
let it do it's thing, click install, enter your key, it will ask if you to
upgrade or compelte install.
judy
"Piet Fourie" <pietfo@telkomsa.net> wrote in message
news:C6ABB3CA-03C8-4E1A-8B97-ECD3D48B8C69@microsoft.com...
> it, as it does not want to work. It complains Autorun.dll could not be run
> or a problem with SPWIZENG.DLL ??
> Piet
Old 10-09-2006   #3 (permalink)
peter
I used the Setup.exe file on the DVD from within Vista RC1 and it upgraded
nicely....but it took about an hour and a half.
how did you try to upgrade??
peter
> Piet
sp1 install problem Windows Updates
WLM Install problem Vista mail
RC 1 Install Problem Vista installation & setup
RC1 install problem: Disk does not meet the criteria to install vi Vista installation & setup
Yet another install problem Vista installation & setup
