| | AIM Trition Issues Okay I have Vista RC1 and use AIM to talk to some of my friends. At first, AIM worked fine on Vista. But within the last week or so, it has been messing up. What usually happens is, the program won't even load, then after I reinstall it, it works then messes up later. I can get it to work but I have to uninstall it and then reinstall it and it works. It just gets annoying and I was wondering if there is a fix to this problem. Thanks |
| | Re: AIM Trition Issues Have you tried running it in compatibility mode yet? Bill F. "NoSpinVette" <NoSpinVette@discussions.microsoft.com> wrote in message news:1530F2C2-C220-4E85-80C7-D0D5E9E64757@microsoft.com... > Okay I have Vista RC1 and use AIM to talk to some of my friends. At first, > AIM worked fine on Vista. But within the last week or so, it has been > messing > up. What usually happens is, the program won't even load, then after I > reinstall it, it works then messes up later. I can get it to work but I > have > to uninstall it and then reinstall it and it works. It just gets annoying > and > I was wondering if there is a fix to this problem. Thanks |
| | Re: AIM Trition Issues Yeah I have to set to Windows XP SP2. It worked fine until about a week ago. It works and then freezes then sometimes it doesn't load at all. I'm just wondering if there is a way to fix it thats all. "Bill Frisbee" wrote: > Have you tried running it in compatibility mode yet? > > > Bill F. > "NoSpinVette" <NoSpinVette@discussions.microsoft.com> wrote in message > news:1530F2C2-C220-4E85-80C7-D0D5E9E64757@microsoft.com... > > Okay I have Vista RC1 and use AIM to talk to some of my friends. At first, > > AIM worked fine on Vista. But within the last week or so, it has been > > messing > > up. What usually happens is, the program won't even load, then after I > > reinstall it, it works then messes up later. I can get it to work but I > > have > > to uninstall it and then reinstall it and it works. It just gets annoying > > and > > I was wondering if there is a fix to this problem. Thanks > |
| | Re: AIM Trition Issues AOL currently has a AIM 6.0 for Vista Beta: http://beta.aol.com/projects.php?project=triton&loc=32 Give that a try. Bill F. "NoSpinVette" <NoSpinVette@discussions.microsoft.com> wrote in message news:B71D10DD-B853-4ABA-BA76-793B6506E688@microsoft.com... > Yeah I have to set to Windows XP SP2. It worked fine until about a week > ago. > It works and then freezes then sometimes it doesn't load at all. I'm just > wondering if there is a way to fix it thats all. > > "Bill Frisbee" wrote: > >> Have you tried running it in compatibility mode yet? >> >> >> Bill F. >> "NoSpinVette" <NoSpinVette@discussions.microsoft.com> wrote in message >> news:1530F2C2-C220-4E85-80C7-D0D5E9E64757@microsoft.com... >> > Okay I have Vista RC1 and use AIM to talk to some of my friends. At >> > first, >> > AIM worked fine on Vista. But within the last week or so, it has been >> > messing >> > up. What usually happens is, the program won't even load, then after I >> > reinstall it, it works then messes up later. I can get it to work but I >> > have >> > to uninstall it and then reinstall it and it works. It just gets >> > annoying >> > and >> > I was wondering if there is a fix to this problem. Thanks >> |
| | Re: AIM Trition Issues Tried it and all it does it freeze up. I had the old aim 5.9 for a while and now it has stopped working. I am forced to use the aim from aim.com, the express one and it sucks. Is there any aim or im program that lets me use my current im address? I have read a few others and will try aim pro. If anyone knows one that works, please tell me. Soon I will be running Vista RC2 and see if that changes anything. Thanks "Bill Frisbee" wrote: > > > AOL currently has a AIM 6.0 for Vista Beta: > http://beta.aol.com/projects.php?project=triton&loc=32 > > Give that a try. > > > Bill F. > > > "NoSpinVette" <NoSpinVette@discussions.microsoft.com> wrote in message > news:B71D10DD-B853-4ABA-BA76-793B6506E688@microsoft.com... > > Yeah I have to set to Windows XP SP2. It worked fine until about a week > > ago. > > It works and then freezes then sometimes it doesn't load at all. I'm just > > wondering if there is a way to fix it thats all. > > > > "Bill Frisbee" wrote: > > > >> Have you tried running it in compatibility mode yet? > >> > >> > >> Bill F. > >> "NoSpinVette" <NoSpinVette@discussions.microsoft.com> wrote in message > >> news:1530F2C2-C220-4E85-80C7-D0D5E9E64757@microsoft.com... > >> > Okay I have Vista RC1 and use AIM to talk to some of my friends. At > >> > first, > >> > AIM worked fine on Vista. But within the last week or so, it has been > >> > messing > >> > up. What usually happens is, the program won't even load, then after I > >> > reinstall it, it works then messes up later. I can get it to work but I > >> > have > >> > to uninstall it and then reinstall it and it works. It just gets > >> > annoying > >> > and > >> > I was wondering if there is a fix to this problem. Thanks > >> > |
| Sli Issues | Vista Games | |||
| RC1 to RTM Issues | Vista installation & setup | |||
| Several Issues... | Vista installation & setup | |||
| HP issues | Vista installation & setup | |||
