| | Right click context menu Hi I'm hoping someone can help me with a wierd problem that's suddenly appeared over the last 2 weeks. For some reason, I've got no right click context menu on files. I've got it on folders and drives, buit not files. All I get is a narrow grey box with up/down arrows on the left side and nothing else. I've googled for similar problems but only found a link to MS that had a reg file to restore context menu. I ran it, but it didn't work. I've also tried a menu viewer which says that the context menus are enabled and there are no problems. TIA Seven |
| context menu/right click | Vista performance & maintenance | |||
| Context Menu Appears without right click | Vista performance & maintenance | |||
| Right Click Context Menu Help | Vista General | |||
| Loosing right click context menu in every application ... | Vista file management | |||
