Vista - Remote Desktop client default settings
Old 03-30-2009   #1 (permalink)
Joe Grover
Some weeks back I enabled the ability to share my local drives with a PC I
was remoting into. Ever since then this option is enabled in every RDP
session I start. I can go in and uncheck the option, but I'm having to do
that every time I remote into a machine, even though I'd not used this
setting on these machines before.
Is there a way I can wipe out any saved RDP settings en masse and start
over? I'm using Vista Ultimate SP1.
Remote Desktop CLient CPU usage Vista General
Remote Desktop client default settings Vista General
Remote Desktop Vista Client Vista networking & sharing
Remote desktop client Vista General
Remote client rdp file settings supported Vista installation & setup
