Vista - How to display clock at system tray
Old 10-10-2006   #1 (permalink)
churin
How can I have clock display at the system tray as that on Windows XP?
Old 10-10-2006   #2 (permalink)
Gene Fitz
RE: How to display clock at system tray
You should be able to get the clock my right clicking the toolbar, and under
toolbar properties, check the box beside "show clock"
Usually, by default, windows places the clock on the toolbar.
I removed mine. I got the digital clock "Gadget" for my sidebar..
Old 10-10-2006   #3 (permalink)
churin
Re: How to display clock at system tray
Thanks. This has been resolved.
A clock in the Gadget I see is only *analogue* clock, not *digital*
clock. Do you mean the analogue clock?
Old 10-10-2006   #4 (permalink)
Kevin L. Kitchens
churin wrote:
>> under toolbar properties, check the box beside "show clock"
I believe you can change the settings to a digital one.
Old 10-10-2006   #5 (permalink)
churin
Kevin L. Kitchens wrote:
> churin wrote:
>>> and under toolbar properties, check the box beside "show clock"
It appears there is no way to change it.
Solved tray clock showing date General Discussion
Can't access system tray or windows clock Vista performance & maintenance
Show seconds on clock in System tray? Vista General
systray clock display Vista General
Weeknumbers in the tray clock/Calendar Vista General
