| | Remote Desktop client default settings I apologize if this is a double-post. I'm using Windows Mail on Vista Ultimate and do not see my post listed. Some weeks back I enabled the ability to share my local drives with a PC I was remoting into. Ever since then this option is enabled in every RDP session I start. I can go in and uncheck the option, but I'm having to do that every time I remote into a machine, even though I'd not used this setting on these machines before. Is there a way I can wipe out any saved RDP settings en masse and start over? I'm using Vista Ultimate SP1. |
| Vista Ultimate x64 & x32 | Re: Remote Desktop client default settings Joe, Sounds like you may have saved over the default Remote Desktop configuration. No worries, this is a pretty quick fix. In Vista, click on Start and type in MSTSC.EXE. When the remote desktop window opens, clear the value from the Computer box. So that it is blank. Then click on Options and go to Local Resources tab. Uncheck the share local drives option. Continue through each tab and set the options as you would like them to be for each new MSTSC connection, then return to the General Tab. From there, verify the computer name is blank and then click on Save As. In your Documents folder is a hidden file named Default.RDP, this is the default configuration that is used for all new Remote Desktop Connections. You will save over this and replace it. This will correct the issue with you having to uncheck the share local drives option for all new connections. For connections you use frequently, you will want to repeat the procedures above, then save them with a new name. Mac Federal IT Systems Engineer Washington DC Last edited by macanannym; 04-01-2009 at 10:58 AM.. Reason: Clarity |
| | Re: Remote Desktop client default settings Looks good, that's exactly what I was looking for. Thanks! Joe "macanannym" <guest@xxxxxx-email.com> wrote in message news:45b11b9c55a5ca16c1098ab148f7e073@xxxxxx-gateway.com... Quote: > > Joe, > > Sounds like you may have saved over the default Remote Desktop > configuration. No worries, this is a pretty quick fix. > > In *Vista*, click on *Start *and type in *MSTSC.EXE*. When the remote > desktop window opens, clear the value from the Computer box. So that it > is blank. > > Then click on *Options *and go to *Local Resources *tab. Uncheck the > share local drives option. > > Continue through each tab and set the options as you would like them to > be for each new *MSTSC *connection, then return to the *General Tab*. > From there, verify the computer name is blank and then click on *Save > As*. > > In your *Documents* folder is a hidden file named *Default.RDP*, this > is the default configuration that is used for all new Remote Desktop > Connections. You will save over this and replace it. This will correct > the issue with you having to uncheck the share local drives option for > all new connections. > > For connections you use frequently, you will want to repeat the > procedures above, then save them with a new name. > > Mac > Federal IT Systems Engineer > Washington DC > > > -- > macanannym |
| Remote Desktop CLient CPU usage | Vista General | |||
| Remote Desktop client default settings | Vista General | |||
| Remote Desktop Vista Client | Vista networking & sharing | |||
| Remote desktop client | Vista General | |||
| Remote client rdp file settings supported | Vista installation & setup | |||
