Vista Forums Home Join Vista Forums Tech Publications Windows 7 Forum Vista Tutorials Webcasts Tags
Welcome to Vista Forums we are your forum for Windows Vista help and discussion. Whether you need help or just want to post an idea you have on Vista, this is the forum for you.
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Vista Build 5384: IE does not display web pages
Update your Vista Drivers
Thread Tools Display Modes
Old 05-30-2006   #1 (permalink)
Matt
Guest
Just downloaded and installed Vista Build 5384 Home Premium on a Shuttle
SN41G2, all installed fine but cannot access the internet???
Most sites do not display at all they just sit loading, google only shows
the links for images groups etc, no search box. I've installed firefox
this does the same. Has anyone seen this before?
It's probably some thing I've done wrong, I thought that it might be
networking issue, but I'm able to copy data to the Vista PC, ping google,
and download the newgroups, so it appears to be in the html rendering
process as not of the help screens or windows update appear to work either.
Any ideas???
Thanks
Matt
Old 05-30-2006   #2 (permalink)
Josh
Guest
Re: Vista Build 5384: IE does not display web pages
Did you do an upgrade?
What are the Internet option settings?
do you have a proxy?
can you ping addresses outside your box? ie, is the network connection
working...
josh
"Matt" <none> wrote in message news:Xns97D4E9CF0CE75none@207.46.248.16...
> Hi,
> either.
> Any ideas???
> Thanks
> Matt
Old 05-31-2006   #3 (permalink)
Matt
Guest
Hi Josh
Nope it was a fresh install on new HDD, I can resolve and ping external
addresses (DNS is OK), the first couple of lines of html code are downloaded
into IE (as the title appears on the browser), but then it just stops. The
same occurs if I try to download a file from the internet the first few KB
are downloaded then it comes to an abrupt stop. It's very bizarre!!
Cheers
Matt
"Josh" <josh@nospam.windowsconnected.com> wrote in message
news:3C1277B4-B07E-4B73-9D63-25AFC8845496@microsoft.com...
> working...
> josh
>> Hi,
>> either.
>> Any ideas???
>> Thanks
>> Matt
Old 05-31-2006   #4 (permalink)
Simon
Guest
if you telnet to the web site, eg
telnet www.microsoft.com 80
and do a GET on the URL, do you see ALL the HTML?
Steve
> Hi,
> either.
> Any ideas???
> Thanks
> Matt
Old 06-04-2006   #5 (permalink)
Matt
Guest
Hi Simon,
Thanks for this suggestion
I've tried that but I don't get anything back (I connect to the site OK).
I'm sure I'm doing something wrong as I get the same on a working XP
machine, please can you type out the exactly what I need to type to GET the
url
Cheers
Matt
"Simon" <Simon@NOSPAM.co.uk> wrote in message
news:e4n%23i5KhGHA.5104@TK2MSFTNGP04.phx.gbl...
> Steve
>> Hi,
>> either.
>> Any ideas???
>> Thanks
>> Matt
Old 06-09-2006   #6 (permalink)
valentin
Guest
Hi
I have exactelly the same problems as Matt, google and his searh appears
with no problems and some others (rare) pages but in the globality the pages
arent displayed.
Why does google appears and nothing other?
"Matt" wrote:
> Hi Simon,
> url
> Cheers
> Matt
> > Steve
> >> Hi,
> >> either.
> >> Any ideas???
> >> Thanks
> >> Matt
Old 06-09-2006   #7 (permalink)
valentin
Guest
RE: Vista Build 5384: IE does not display web pages
Hi
I have exactly the same problem : google and all his domain' pages work, but
no others sites.
I think thats comes from my router (comtrend ct-633) because when I share my
connection from an other pc with this router i have this trouble but when i
share my connection with my old modem (sagem f@st 800) i have no problems?
anyone know why router bugs?
"Matt" wrote:
> Hi,
> Any ideas???
> Thanks
> Matt
Old 06-09-2006   #8 (permalink)
CS
Guest
I'm also having this exact same problem and it is somehow related to the
router. I have this problem with one of our gateways. When I use it I can
get google ok but experience the same issues as the other posters with most
other websites. This is the same router that I used with XP perfectly and
that around 100 users currently use with XP just fine. So it's not the
router. I think Vista is doing somehting the router doesn't like. If I
switch to the other gateway/router I can browse the internet correctly. I'm
looking at packet captures to try to figure out what's going on...
"valentin" wrote:
> Hi
> no others sites.
> "Matt" wrote:
> > Hi,
> > Any ideas???
> > Thanks
> > Matt
Old 06-09-2006   #9 (permalink)
valentin
Guest
hi cs
when i said thats the router i want to said thats the router and vista,
because like you i havent any problem with xp
> "valentin" wrote:
> > Hi
> > no others sites.
> > "Matt" wrote:
> > > Hi,
> > > Any ideas???
> > > Thanks
> > > Matt
Old 06-09-2006   #10 (permalink)
Antoine
Guest
I have the same problem.
Just google and www.cuteftp.com.
I have a router and with a dial up modem, i can naviguate
Display Modes
Cannot Activate Vista Build 5384 =?Utf-8?B?TWljaGFlbE1hbmdlbHNkb3JmZg==?= Vista General 5 08-20-2006 04:16 AM
Windows Vista Beta 2, Build 5384 =?Utf-8?B?SlI=?= Vista installation & setup 1 08-08-2006 08:18 PM
Vista public build 5384, nerds build 5472 =?Utf-8?B?R3J1bXB5?= Vista General 7 07-30-2006 10:18 AM
Vista build 5384 Internet not connected =?Utf-8?B?U2lh?= Vista networking & sharing 0 07-20-2006 05:03 PM
winmail in vista build 5384 Kue2 Vista General 2 06-26-2006 04:17 PM
Complimentary Industry Resources
Vista Forums has joined forces with TradePub.com to offer you a new, exciting, and entirely free professional resource. Visit http://vistax64.tradepub.com today to browse our selection of complimentary Industry magazines, white papers, webinars, podcasts, and more across 34 industry sectors. No credit cards, coupons, or promo codes required. Try it today!
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
