| | trying to print webpages - only 1 page will print Hello There is a webpage I want to print. The webpage is quite long , perhaps 6 or 7 A4 sheets, but whenever I try to print it I get only one sheet printed. . Print preview says there is only 1 page to actually be printed (print page 1 of 1). There should be 6 or 7 pages. How do I get the whole thing to print. ? Thanks KK |
| | Re: trying to print webpages - only 1 page will print "KRK" <trebor@xxxxxx> wrote in message news:OgnNULFtJHA.5516@xxxxxx Quote: > Hello > > There is a webpage I want to print. The webpage is quite long , > perhaps 6 or 7 A4 sheets, but whenever I try to print it I get only > one sheet printed. . Print preview says there is only 1 page to > actually be printed (print page 1 of 1). There should be 6 or 7 > pages. How do I get the whole thing to print. ? > Thanks > KK If I wanted to print a web page to a hard copy through my printer I may do the following Navigate to the web page ((I use IE7) in Vista Sp1) I wish to print out and make sure the page is fully down loaded (look it over or check status bar). At this point from the Menu bar click on File and choose Print Preview. Print Preview opens and displays the first page and by default sets Shrink To Print. I notice this is a multiple page print job, because at the bottom of the Print Preview window there is a navigation bar that shows up when a print job will be more than one page. And there are buttons to navigate and view each page. I look things over and make any or no changes to page setup or any other of the no telling how many options and things I have control over at this point. Being satisfied with the preview I can select/click the print icon or close Print Preview and click on File then click on Print from the context menu. Either way a Print dialog box opens so I can chose the printer for the job and also issue instruction by selecting them. These are the instructions that Vista will send to the printer I chose. I make my selections, click Apply then click Print. The operating system sends/hands off all the instructions to the printer software/driver this then activates the printer hardware and if the printer has enough paper and ink it prints out the job. Note: From start to finish of a print job there are many, many options that can be selected and many things that can widely vary what any one person may chose compared to someone else. Because I know what my default settings are, I could have said, go to the web page, click on File>Print, from print dialog box click the Print button. How do you print out your multiple page printing job using what you are using ? What Web Browser and its version number are you using? What operating system are you using? e.g. Vista HP Sp1 or what? Is this print job something you have done many times before and now its not working as expected.? If so what has changed from then and now? H Brown |
| When I print webpages | Vista print fax & scan | |||
| Vista last page does not print -with print server | Vista print fax & scan | |||
| Re: ie7 wont print webpages | Vista print fax & scan | |||
| Won't print webpages with my HP 5650 Inkjet Printer | Vista print fax & scan | |||
