| | Problem with system restore. It seems no posible to restore the system from previous "restore points" with Vista Bussines. I always get the message "System restore did not complete succesfully. Details: The writer experienced a transient error (0x800423F3)." I would much appreciate any help. |
| | Re: Problem with system restore. On Wed, 8 Apr 2009 06:05:15 -0500, "Maqueda" <Johnny.Maqueda@xxxxxx> wrote: Quote: > It seems no posible to restore the system from previous "restore points" >with Vista Bussines. I always get the message "System restore did not >complete succesfully. Details: The writer experienced a transient error >(0x800423F3)." > >I would much appreciate any help. <quote> Here is what I get on that error message: ----- 0x800423F3 vsserror.h The writer experienced a transient error. If the backup process is retried, the error may not reoccur. VSS_E_WRITERERROR_RETRYABLE ----- This likely indicates that the Volume Shadow Copy service is not running and possibly disabled or set to Manual. Open the Control Panel and select Classic View in the Tasks Pane. Double Click Administrative Tools to open and click the 'Services' item. In Services, scroll down to the 'Volume Shadow Copy' service and double click it to open. In the Startup Type drop down menu, select the 'Automatic' option. Click the 'Start' and wait for the indication that it has started. Go to 'System Protection' and try creating another 'System Restore' point. Let us know the results. </quote> HTH -- Noel Paton www.crashfixpc.co.uk Nil Carborundum Illegitemi |
| | Re: Problem with system restore. "Noel Paton" <noeldp/spamless/@crashfixpc.co.uk> wrote in message news:f73pt4p3l6h4tjo8i9f7easi3pd7mucdsi@xxxxxx Quote: > This likely indicates that the Volume Shadow Copy service is not > running and possibly disabled or set to Manual. > Open the Control Panel and select Classic View in the Tasks Pane. > Double Click Administrative Tools to open and click the 'Services' > item. > In Services, scroll down to the 'Volume Shadow Copy' service and > double click it to open. > In the Startup Type drop down menu, select the 'Automatic' option. > Click the 'Start' and wait for the indication that it has started. > Go to 'System Protection' and try creating another 'System Restore' > point. > Let us know the results. try anything else. |
| | Re: Problem with system restore. On Thu, 9 Apr 2009 16:23:01 -0500, "Maqueda" <Johnny.Maqueda@xxxxxx> wrote: Quote: > >"Noel Paton" <noeldp/spamless/@crashfixpc.co.uk> wrote in message >news:f73pt4p3l6h4tjo8i9f7easi3pd7mucdsi@xxxxxx Quote: >> This likely indicates that the Volume Shadow Copy service is not >> running and possibly disabled or set to Manual. >> Open the Control Panel and select Classic View in the Tasks Pane. >> Double Click Administrative Tools to open and click the 'Services' >> item. >> In Services, scroll down to the 'Volume Shadow Copy' service and >> double click it to open. >> In the Startup Type drop down menu, select the 'Automatic' option. >> Click the 'Start' and wait for the indication that it has started. >> Go to 'System Protection' and try creating another 'System Restore' >> point. >> Let us know the results. > Thanks Noel. Unfortunately the problem remains, so we'll need to >try anything else. 'the problem remains' is not very desciptive - what happened at each step of the process? error messages? did the service start? Was it already started? - is it still running? what was the error message when you tried to create a new restore point?? The essence is in the DETAILS! -- Noel Paton www.crashfixpc.co.uk Nil Carborundum Illegitemi |
| | Re: Problem with system restore. > Noel Paton" <noeldp/spamless/@crashfixpc.co.uk> wrote in message Quote: > news:1lsst4lbhcte68e1knc01galgp7c3bp4la@xxxxxx > 'the problem remains' is not very desciptive - what happened at each > step of the process? error messages? did the service start? Was it > already started? - is it still running? what was the error message > when you tried to create a new restore point?? > The essence is in the DETAILS! "System restore did not complete succesfully. The writer experienced a transient error. If the backup process is retried, the error may not reoccur. (0x800423F3)." at the same points, when trying to create a restore point or when trying to restore the system from a previous one. |
| | #6 (permalink) |
| | Re: Problem with system restore. On Fri, 10 Apr 2009 14:23:11 -0500, "Maqueda" <Johnny.Maqueda@xxxxxx> wrote: Quote: Quote: >> Noel Paton" <noeldp/spamless/@crashfixpc.co.uk> wrote in message >> news:1lsst4lbhcte68e1knc01galgp7c3bp4la@xxxxxx >> 'the problem remains' is not very desciptive - what happened at each >> step of the process? error messages? did the service start? Was it >> already started? - is it still running? what was the error message >> when you tried to create a new restore point?? >> The essence is in the DETAILS! > Sorry, I meant that everything remains exactly the same. Same message: > >"System restore did not complete succesfully. The writer experienced a >transient error. If the backup process is >retried, the error may not reoccur. (0x800423F3)." > > at the same points, when trying to create a restore point or when trying to >restore the system from a previous one. > > that error - but personally (and I have NO data to back it up!) I suspect either malware or AV interference. What AV are you using? Have you checked the system for malware lately? -- Noel Paton www.crashfixpc.co.uk Nil Carborundum Illegitemi |
| | #7 (permalink) |
| | Re: Problem with system restore. "Noel Paton" <noeldp/spamless/@crashfixpc.co.uk> wrote in message news:2ai0u453n3sgk2q8jhvbip46fgksftpa7n@xxxxxx Quote: > Unfortunately there's not a lot of data to be found on what causes > that error - but personally (and I have NO data to back it up!) I > suspect either malware or AV interference. What AV are you using? Have > you checked the system for malware lately? got a warning some weeks ago about a "potentially malware file", rated "low danger", something that happens sometimes with no consequences. Maybe I should try to check the system with other AV to be sure about this point. Thanks for your help Noel, I'll inform you and the comunity if I found anything useful. |
| | #8 (permalink) |
| | Re: Problem with system restore. On Mon, 13 Apr 2009 07:03:53 -0500, "Maqueda" <Johnny.Maqueda@xxxxxx> wrote: Quote: >"Noel Paton" <noeldp/spamless/@crashfixpc.co.uk> wrote in message >news:2ai0u453n3sgk2q8jhvbip46fgksftpa7n@xxxxxx Quote: >> Unfortunately there's not a lot of data to be found on what causes >> that error - but personally (and I have NO data to back it up!) I >> suspect either malware or AV interference. What AV are you using? Have >> you checked the system for malware lately? > I use Sophos AV + Zone Alarm firewall and no problem in years. However, I >got a warning some weeks ago about a "potentially malware file", rated "low >danger", something that happens sometimes with no consequences. Maybe I >should try to check the system with other AV to be sure about this point. > Thanks for your help Noel, I'll inform you and the comunity if I found >anything useful. (from http://www.vistaforums.com/Forum/Topic14017-9-1.aspx) <quote> Try the following: 1) Start the computer in Safe Mode without networking. 2) Open a command prompt as administrator 3) Type "net stop winmgmt" without quotes and press enter to make certain the WindowsManagementInstrumentation (WMI) service is not running. 4) Go to the windows\system32\WBEM\ and rename the Repository folder. 5) Reboot and restart as normal 6) Open a command prompt as administrator. 7) Type "net stop winmgmt" without quotes and press enter to stop the wmi service. 8) Type winmgmt /resetRepository and restart the system. See if this works. </quote> HTH! -- Noel Paton www.crashfixpc.co.uk Nil Carborundum Illegitemi |
| system restore Problem | General Discussion | |||
| System Restore Problem | General Discussion | |||
| System Restore problem | Vista General | |||
| problem with system restore | Vista General | |||
| System Restore Problem? | Vista General | |||
