Vista - Bluescreen at startup, safe mode does not work?
Old 04-08-2009   #1 (permalink)
Windows Vista Home Premium 32bit
Hello guys!
I've got this major bluescreen issue. Two days ago, I just restarted my pc for no particular reason, and when it was about to start it gives me this bluescreen.
It starts up, I get the loading bar, but then bluescreen. I tried to chose any of the safe modes, but none of them work, just gives me the bluescreen again.
To sum all this, I canīt start my computer due to a bluescreen issue, not even with safemodes. It gives me alot of text, but the screen dissappears after a few seconds so I canīt even read two lines.
I'm running a HP Pavilion m8055.sc with Windows Vista Home Premium 32bit
Thanks in advance!
// Alecs
Old 04-08-2009   #2 (permalink)
James Kosin
Re: Bluescreen at startup, safe mode does not work?
Elvee wrote:
Quote:
> Hello guys!
> this bluescreen.
> bluescreen again.
> 32bit
> Thanks in advance!
> // Alecs
Does the <pause> keyboard button work?
Without more information, we don't have much to suggest other than maybe
driver issues, virus, malware, bad microsoft patch, etc.
James
Old 04-08-2009   #3 (permalink)
pupick
That type of early blue screen most likely means failed power supply or hard
drive, less likely bad ram.
If you do not know how or have the means to troubleshoot this problem take
the computer to a repair facility and hope it is simply the power supply.
If you have the ability to do so remove the hard drive, install it in a USB
enclosure, and see if you can read and copy its contents from another
computer as soon as you are able to do so.
Old 04-08-2009   #4 (permalink)
Safai
Hi
I would use a rescue CD (Hiren Boot or Ultimate boot) to boot the PC and
recover the data you may have on the system. Then, I think the easiest way
is to reinstall your windows.
Good Luck
Morteza
"Elvee" <guest@xxxxxx-email.com> wrote in message
news:89c5d8abd9e28ce2a4d18ece9ec9acfe@xxxxxx-gateway.com...
Quote:
> Hello guys!
> this bluescreen.
> bluescreen again.
> 32bit
> Thanks in advance!
> // Alecs
> Elvee
Old 04-08-2009   #5 (permalink)
Quote  Quote: Originally Posted by James Kosin View Post
Elvee wrote:
Quote:
> Hello guys!
> this bluescreen.
> bluescreen again.
> 32bit
> Thanks in advance!
> // Alecs
James
I'll try that out, and then I'll simply post whats on my screen here. Thanks for fast response!
Also thanks to pupick, I guess thats what I need to do if nothing else works.
Thanks again
//Alecs
Old 04-08-2009   #6 (permalink)
The <pause> key does not work, atleast it doesnt stop the screen from dissappearing :/
Old 04-08-2009   #7 (permalink)
Elvee wrote:
Quote:
> Hello guys!
> this bluescreen.
> bluescreen again.
> 32bit
> Thanks in advance!
> // Alecs
James
I took a picture with a digital camera and wrote the error message down:
A problem has been detected and Windows has been shut down to prevent damage to your computer.
A process or thread crucial to system operation has unexpectably exited or been terminated.
If this is the first time you've seen this Stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory operations such as caching or shadowing.
If you need to use Safe Mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical information:
*** STOP: 0x000000F4 (0x00000003, 0x88253B18, 0x88253C64, 0x82C82430)
Collecting data for crash dump ...
Initializing disk for crash dump ...
Beginning dump of physical memory.
Dumping physical memory to disk: 20
The last "Dumping physical memory to disk" goes up to 100 in a few seconds and then the computer restarts...
//Alecs
Old 04-08-2009   #8 (permalink)
James Kosin
Elvee wrote:
Quote:
> James Kosin;1013883 Wrote:
Quote:
>> Elvee wrote:> > >
Quote:
>>>> Hello guys!
>>> my
>>> me
>>>> this bluescreen.
>>>> bluescreen again.
>>>> 32bit
>>>> Thanks in advance!
>>>> // Alecs
>> maybe
>> James
> down:
> or been terminated.
> these steps:
> manufacturer
> shadowing.
> select Safe Mode.
> //Alecs
Hmmm....
Now I'll have to check why my computer was rebooting when I tried to
upgrade the memory to 1.5GB.
Try just installing 1GB of memory. I know it sounds silly and stupid.
James
Old 04-08-2009   #9 (permalink)
Elvee wrote:
Quote:
>> Elvee wrote:> > >
>> maybe
>> James
> down:
> or been terminated.
> these steps:
> manufacturer
> shadowing.
> select Safe Mode.
> //Alecs
Hmmm....
James
Could the ram be the problem? I've had this computer for years without a single hardware upgrade, no problems until now. Could it be a hardware issue?
//Alecs
Old 04-09-2009   #10 (permalink)
James Kosin
Elvee wrote:
Quote:
> James Kosin;1014338 Wrote:
Quote:
>> Elvee wrote:> > >
Quote:
>>>> James Kosin;1013883 Wrote:> > > > >
>>>>>> Elvee wrote:> > >
>>>>>> maybe
>>>>>> James> > > > >
>>> message
>>>> down:
>>> prevent
>>> exited
>>>> or been terminated.
>>>> these steps:
>>> installed.
>>>> manufacturer
>>> hardware
>>>> shadowing.
>>> restart
>>> then
>>>> select Safe Mode.
>>> 0x82C82430)
>>> few
>>>> //Alecs
>>>>>> Hmmm....
>> stupid.
>> James
> Could the ram be the problem? I've been having this computer for years
> hardware issue?
> //Alecs
Could be, but I was asking because I tried to recently upgrade my
computer with more than 1GB of memory and VISTA would not stop BSOD on
me until I took out the extra (upgrade memory).
It could also be a VISTA patch that may have caused this. How old and
how much memory?
James
Safe Mode Startup General Discussion
MSCONFIG Boot - Stuck in Safe Mode or Selective Startup Vista performance & maintenance
Stuck in Safe Mode in Normal Startup mode need help! Vista performance & maintenance
Only Work in Safe Mode Vista installation & setup
Install fine but only safe mode will work Vista installation & setup
Đ Designer Media Ltd
