Vista - Mobile Device Center (Beta 3) Issues
Old 10-11-2006   #1 (permalink)
Dan swartz
I recently updated my RC1 to RC2 and downloaded the Mobile Device Center
(Beta 3) package from here:
http://www.microsoft.com/windowsmobi...icecenter.mspx
My problem is when I run the installer nothing happens. I double click it
and it looks like it will run but nothing ever happens.
I am logged in as a user with Admin rights, I re-downloaded the installer,
and I tried it on 2 separate machines with the same results. Anyone have any
ideas?
Dan Swartz
PS
One system is a Dell Optiplex, 1.5 gig ram, 200 gig HD Only Vista RC2 and
Office 2k7, the other is a homebuilt P4 3 Gig HT, 2 gig RAM 300 Gig HD and
only Vista RC2 Office 2k7
My Device is Treo 700 WM5
Supposedly Office 2K7 reports as Office 2k3 if this ever runs the install.
Old 10-11-2006   #2 (permalink)
Max
Re: Mobile Device Center (Beta 3) Issues
Have you actually *connected* your mobile device(s) yet?
Maxwell Bluemeanie
"Dan swartz" <Danswartz@discussions.microsoft.com> wrote in message
news:40F63EEA-2250-4273-8D61-C7028A9805F5@microsoft.com...
> any
> ideas?
Old 10-11-2006   #3 (permalink)
Dan swartz
No, is that part of it's set up? The install instructions did not say anythng
like that.
> Maxwell Bluemeanie
> > any
> > ideas?
Old 10-11-2006   #4 (permalink)
Max
Try it and see.
Documentation is lacking. It's BETA.
Maxwell Bluemeanie
news:B324B877-3F80-4A67-9814-55B7753BCC43@microsoft.com...
> anythng
> like that.
>> Maxwell Bluemeanie
>> > it
>> > installer,
>> > have
>> > any
>> > ideas?
Old 10-11-2006   #5 (permalink)
Dan swartz
Oh, I know, I guess I just want it flawless. :-)
I'll try and report back. Thanks for the input.
"Max" wrote:
> Try it and see.
> Maxwell Bluemeanie
> > anythng
> > like that.
> >> Maxwell Bluemeanie
> >> > it
> >> > installer,
> >> > have
> >> > any
> >> > ideas?
Old 10-12-2006   #6 (permalink)
Dan swartz
Yup, that was it. Thanks Max.
I had an odd issue where it wouldn't syn but I rebooted my PC and my Treoo
700 and all worked fine after that.
So if anyone else is reading this,
Step 1 down load the software
Step 2 install the software
Step 3 connect your device
Should work
If not reboot both your PC and your device to try again.
> "Max" wrote:
> > Try it and see.
> > Maxwell Bluemeanie
> > > anythng
> > > like that.
> > >> Maxwell Bluemeanie
> > >> > it
> > >> > installer,
> > >> > have
> > >> > any
> > >> > ideas?
Old 10-12-2006   #7 (permalink)
Max
You're welcome.
Worked for me.
Now if only The Others would read this thread before starting another one
with the same issue.
Maxwell Bluemeanie
news559EB5B-6E84-4161-BF3A-DE27A61047F3@microsoft.com...
> Should work
>> "Max" wrote:
>> > Try it and see.
Old 10-16-2006   #8 (permalink)
erol
Hi Max!
Doesn't work everywhere. I've got a Samsung i730. Not one of the versions,
since Vista Beta 1 has recognized my phone. Latest WMDC beta 3 DOES show a
device driver being installed, BUT no device is added to device manager, even
though it refreshes several times (on install, connect, disconnect). Have
rebooted, even prayed and left posts here.
No one will reply to this... can you?
Cheers!
Erol
"Max" wrote:
> You're welcome.
> Worked for me.
> Maxwell Bluemeanie
> > Should work
> >> "Max" wrote:
> >> > Try it and see.
Mobile Device Center Issues Vista General
Can't run Mobile Device Center Beta 3 in RC1 Vista General
Mobile Device Center beta 3!!! Vista General
mobile device center beta v2 Vista installation & setup
Mobile Device Center Beta Vista General
