| Vista Home Premium 32bit | Installed Microphone wont work basically, ive checked the sounds, it says the microphone is working, but i try to record but nothing happens. i have windows vista home edition |
| | Re: Installed Microphone wont work On Fri, 10 Apr 2009 19:41:48 -0500, wwedan <guest@xxxxxx-email.com> wrote: Quote: > >basically, ive checked the sounds, it says the microphone is working, >but i try to record but nothing happens. i have windows vista home >edition |
| Vista Home Premium 32bit | Re: Installed Microphone wont work how do i check lol? it says the volume etc is up |
| | Re: Installed Microphone wont work Check if "microphone" is default audio recording device or "line in" is default. To check goto control panel>sound>recording. To set microphone as default right click on microphone and click set as default. Apply it and try to record. Another thing is if you are using HP laptop and using a normal audio jack external microphone then keep that jack little (about 2-3mm) outside the point then only it will work. I hope it helps. -- Vanshaj Daga vanshajdaga2002net@xxxxxx http://www.ak****agroup.co.cc "wwedan" wrote: Quote: > > how do i check lol? it says the volume etc is up > > > -- > wwedan > |
| Vista Home Premium 32bit | Re: Installed Microphone wont work i right clicked and nothing said default? :s how do i change the jack? it says 3.5 mm |
Microphone wont work | Sound & Audio | |||
| re-installed Ultimate -- remote control wont work anymore.. | Vista General | |||
| Installed microphone on notebook not working | Vista General | |||
| vista installed games wont work | Vista Games | |||
| Microphone Wont Connect | Vista General | |||
